Rear valence swappers, look here please
  • naika
    • 466
    To be honest Luke, the only thing I would change about how I did it is to have prepped the area where I mounted it better. I would have stripped all the paint and everything down to the bare metal on both the valance and the existing area of the car. When we were welding mine on, the paint/undercoating around the welds kept catching on fire, and we had to douse it out each time.
    Also, I probably would have stripped all of the undercoating off of the new valance, like I did with my front valacnce. Once I get my sideskirts on, it will look kind of funny because it will be the only part of the car that's textured. But if I have the cash soon, I'm going to get one of the Eurostyle M-Tech II rear valances like nando and backtrail have.
    I will tell you though, cutting that valance down to the usable size was something of a serious pain in the ass, and you have to be careful that you don't cut into an area you want to save. It's easier than you'd think to fuck it up, we came close a couple of times. If you want, I can zip up all the pics of the whole cutting/installation and email it to you.
    Do you have a link to the Eurostyle M-tech II rear skirt? I'm looking at installing front and back and can't find a link to this anywhere
    Thanks
    344is! Obd1 conversion
    • der affe
      Technical
      • Dec 2005
      • 8452
      or you could put a dent in your Snap-on account and get one of these and some spare wire wheels:
      Catalog Index Power Tools, Air Speciality Air Tools Remove-All Tool
      View Larger Image
      Image shown may not be actual
      product but represents product
      or set which includes product
      Email a Friend Tell others about this Snap-on item. Add to your Wish List Organize your list for later reference.
      Plan and prioritize for future purchases.
      Email your wish list to friends & family.
      Printable Page Display a printer-friendly page. Bookmark Page Save this page to view later.
      Tool, Air, Crud Removal
      ItemQtyPrice** Tool, Air, Crud Removal Stock#: PT280THUGA
      $414.00
      Add To CartCheckout
      Description:
      Quickly remove seam sealers, rust and paint and underbody protectors. Optional rubber eraser wheel for pinstripe and graphics removal. Tool easily removes automotive "crud" without fumes, heat build-up or surface damage. Thermally-balanced Air Motor routes air between housing and liner for cooler tool temperatures and longer life. Includes one (1) fine wire wheel and one (1) coarse wire wheel.
      Features:
      • Planetary Gear System for increased torque.
      • Ergonomic Cushion Grip insulates against cold and vibration.
      • Adjustable Exhaust Outlet in rear of tool allows choice of exhaust direction.
      • Ten-Position Power/Speed Regulator allows easy RPM adjustment.
      • Paddle Style Trigger for precise speed control.
      Product SpecificationsStock #PT280THUGA NameTool, Air, Crud RemovalPrice** $414.00 BrandSnap-on Recommended Air Pressure, psig (kPa)90 (620)Free Speed, rpm3,500Sound Level, dBa85Air Inlet Thread Size1/4"-18 NPTRecommended Hose Size, inches (mm)3/8 (10) ID Min.Length, inches (mm)12 (305)Weight, lbs. (kg)2.4 (1.1)Rubber Eraser Wheel (opt.)PT280303MP3Air Consumption, average, cfm (scfm) [l/min]4 (28.5) [113.3]Coarse Wheel (incl.)1 eachFine Wheel (incl.)1 eachCheckout
      SNAP-ON is a trademark of Snap-on Incorporated. Other marks are marks of their respective holders. ©2008 Snap-on Incorporated. All rights reserved.
      By accessing and using this web site, you agree that you have read and are bound by the terms and conditions set forth in the Terms and Conditions of Use, including the arbitration provisions.
      **If you have a Snap-on Dealer and wish to purchase from your Dealer, your Dealer sets his or her own prices. Any products that you wish to purchase directly from your dealer, please see your Dealer.
      Home | Snap-on Store | Corporate Information | Own a Snap-on Franchise |
      Other Snap-on Sites | FAQs
      Web Site Comments | Privacy Policy | Terms and Conditions of Use |
      Terms of Sale (Warranty Information) | Customer Service
      Hand Tools | Power Tools | Diagnostics | Tool Storage | Shop Equipment
      Part No Index | Keyword Index
      they will make short work of anything not metal. you can usually get them for around $350ish from the truck, or try your luck on E-bay. if you do bodywork for a living they are your best friend!
      there a couple of different ones out there Wurth offers one similar to this for around $100 cheaper. Dent-fix also offers one that is a converted cutoff/die-grinder with an internal air pressure regulator to slow it down. that one goes for around $200-$250 depending on your source. they are kind of awkward to use and don't reach into tight spaces well though.
      • Jand3rson
        • 37587
        Luke, I'm not bullshitting. I'll bring my sawzall and come over there and show that bitch who's in charge.
        Then I'll cut that valance up for you. :D
        • JasonC
          Site Manager
          • 14451
          Originally posted by monty
          tools to scrape undercoating off...
          1. a 1 inch wide strong putty knife
          2. a heat gun
          3. about 2 hours of your time if you are going to do front and back.
          That's the best way of doing it IMO. But i use a little hand held propane torch.
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
