Damn welder jammed !
  • Jordan325iC
    • Aug 2005
    • 1697
    I've got a cheap little Century 80amp flux-core welder. Looks like this:
    I ran out of welding wire today just before I started welding up my exhaust. When I re-loaded it, the wire broke when it had run a few feet into the hose. My attempts to fish it out failed and now that welding wire is stuck a foot or two in. This blocks me from running more wire through the gun.
    Here is a picture of the welder in its current state of disassembly:
    On the left, you see the inner metalic hose with the short piece of rubber hosing on the end where the wire feeds in.
    You can also see the gun with the cover removed on the right.
    This is my first welder and I have no instruction booklet, so I'm at a loss for how to get that piece of wire out from the gun hose, and I really don't want to take it apart any more without knowing what I'm doing. Any help or advice?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • der affe
    Technical
    • Dec 2005
    • 8452
    just to clarify....the wire is stuck in the liner (the hose leading from the welder to the gun) right?
    it looks like you bought it used, prob. if it has super hours on it you may need a new liner. just the hose part, not the gun in most cases.
    if you need to get one, may i suggest these people
    Slot Server Thailand ialah Platform 🛩️ Situs Online terbaik sebagai bandar judi Internasional terutama Slot Server Thailand Link Alternatif PG Soft Gaming Indonesia paling utama. Jenis permainan dari Provider PG Soft yang paling banyak di minati di Slot Thailand jelasnya Mahjong ways 1 dan 2 kini ada jam gacor tersendiri di mana mesin Slot Server Thailand.
    great prices and helpful people
    • der affe
      Technical
      • Dec 2005
      • 8452
      if you have to buy the whole thing, gun included see if this will work on your welder:
      i up graded to this on my matco wfw160 and love the shit out of it!! it is small so it fits in places where a regular mig gun will not fit.
      • Jordan325iC
        • Aug 2005
        • 1697
        Yes, that's correct.
        This welder has been doing me very well, but it's just a temporary one. I will be replacing it with a real MIG sometime soon, so I'd rather not spend any money on it.
        Furthermore, the only thing keeping me from dropping the car off the jack-stands and driving it is this exhaust, so I reallly don't want to have to wait a week or two for some part to ship to me if there was just some sort of temp fix I could do. Even if I bought the new liner, I still don't have any clue how to disconnect it from the gun (if I did, I would just do that right now and run a coat hanger down it to get the rouge wire out).
        '88 325is
        BMWCCA 380364
        • kowalski
          • Jan 2005
          • 1791
          if its auto feed, just feed more wire in behind it to push it out, or try putting compressed air through it.
          • sumyungguy
            • Feb 2007
            • 1313
            +1.. has worked for me in the past..
            • Huff
              • 2488
              +2 Use a air nozzel and put that in the line. The dude that taught me to weld showed me that trick...
              • newman
                • Mar 2007
                • 1159
                just buy a new liner. they are like 15 bucks.
                1987 325is: 495whp/400ft-lb
                UPDATED 03/12/10!: RB26DETT Swapped E30
                • turboeta
                  • Aug 2007
                  • 571
                  I agree with what everyone said about the compressed air, my Miller did this one time...it sucked
                  635csi Euro/Alpina B7S
                  • einstein57
                    • Jun 2007
                    • 10780
                    spin it around like a lasso
                    www.gecoils.com
                    • der affe
                      Technical
                      • Dec 2005
                      • 8452
                      compressed air, yes give it a try. if the liner is frayed inside (it is like a giant coil) you are screwed. if you want to fix it right away call local welding supplies and see if they carry parts for century welders. it shouldn't be that difficult to find parts.
                      DO NOT FORCE MORE WIRE IN TO TRY TO CLEAR IT!!!!!
                      you will make it worse.
