no spark
  • rede30
    • 4697
    no spark
    I cant get a spark to my engine, i have changed the ignition coil, made sure engine is grounded, changed the crank sensor, checked spark plugs and made sure those wires are all in place. what else is there, thanks.
    Dustin
  • E30/M30
    • 224
    Ecu control relay or may be the Ecu it's self is playing up ?
    What type of motor is it m8 ?
    • modifiede30
      • 1208
      Have you done any work to the car recently?
      Driving is the only way to go faster....
      • rede30
        • 4697
        i got a used motor from bavarian auto excange. i put it in and got everyhting hooked up and now no spark. it turns over but wont fire up.
        • modifiede30
          • 1208
          Check to make sure that the jump wire between the main relay and fuel pump relay is present. You should see a red wire running between the two relays. If its there, check to make sure both relays are working. If they are, I would suggest you try to find someone who will let you use they're ecu for testing to see if its the ecu. Just make sure everything is grounded properly or you'll burn it out. While I'm on the subject, are you sure everything is grounded well and that the battery is connected correctly? I know its a dumb question but I have to ask.
          • Beej '86 325es
            • 2639
            What engine is it?
            My eta engine as a reference pin on the flywheel that is used to determine crank position and will not start unless the sensor is picking up that point.
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • rede30
              • 4697
              thanks alout for your help guys i will try those things out. i will tell you what i find out when i find out. thanks agian.
              D
