oil pressure and oil temp sensors
  • The Barvarian
    • 162
    I did a search and looked at the threads but I am still a little confused. I would like to install both an oil pressure and oil temperature sendor. I am looking for the cleanest solution. For the temp sendor is a drain plug adapter the best way to go? I assume I should just replace the original sendor for the oil pressure?
    "Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"
  • CleanAzzE30z
    • Jan 2004
    • 11794
    Im trying to put a Oil pressure gauge in my ///M3. I have the gauge, just havent been able to find the other pieces.
    Mariano
    • cramer
      • 1812
      For oil pressure: if you have the room, you can simply replace the stock pressure switch with the gauge sending unit. The sending units are also available in dual post so you can still hook up your factory idiot light.
      If you do not have the room for the sender, there are a couple ways to go: Buy an adapter plate that shifts the sender mounting point, or do a complete remote mount. You can find these parts at BMP, Bimmerworld etc.
      Chris
      90 Corrado/91 M3/01 M5
      • The Barvarian
        • 162
        THis is what I came up with:
        • eko
          • Mar 2006
          • 372
          Mariano
          Mariano,I always thought all M3`s had a factory pressure gauge in place of the economy gauge?
          94 316i Touring M52B28
          Made in Germany perfected in Britain!
          • PiercedE30
            • Apr 2005
            • 4220
            Use an adapter and a short length of AN hose to mount the sender on the frame rail. Then you can put a distribution block on the end of the AN hose and keep the stock sender.
            My 2.9L Build!
            • cramer
              • 1812
              That's oil temp.
              Chris
              • CleanAzzE30z
                • Jan 2004
                • 11794
                Yeah thats oil temp. ;)
                Mariano
