I have a overheating problem (89 325i) It started late one night while sitting in a drive thru line. It almost got into the red. as soon as I got my food, I took off. The temp went back down to normal instantly. The next day and there after it will get hot unless moving at a good speed or the revs are up. I replaced the coolant temp sensor and ordered a thermostat. But I need to use the car so i put it together without the t-stat. I bled the system and took it for a test drive. It almost hit red really fast. I sprinted home. I felt no coolant or pressure in the hoses. then I took the coolant tank cap off. It was like a hot fire hose, I looked muddy. The fan clutch seems good. I'm frustrated, this is my second E30. My first on I had for 3 years with no problems at all. I recently moved to LA so I bought my second E30. Ever since I've had this one its been nothing but problems, But the body is in great shape. The PO said that he there was a blown head gasket so he had the head reconditioned and reinstalled, with new timing belt, tensioner, and water pump. Any Ideas would be appreciated thanks guys.
Overheating Help
