CMI Engineering Turbo
  • monty
    • Feb 2007
    • 665
    Anyone ever hear of this company? I am looking at the "Street Demon" series Turbo kit, it comes with everything needed,
    -T3/T4 turbo with wet float bearings
    -321 stainless steel manifold
    -2,5" inlet/2.5" outlet intercooler with all the piping
    -boost controler
    -blow off valve
    -cooling fan
    -35mm wastegate
    -electronic turbo timer
    -fuel pressure regulator
    -catch can
    Just wondering if anyone has any feedback on this setup?
  • Jordan325iC
    • Aug 2005
    • 1697
    Never heard of it. Link?
    Also, that's not a complete kit. You still need exhaust, fuel/spark management and gauges.
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
    • e30Matt
      • 5077
      Are "wet float bearings" a fancy way of saying "bushings"?
      • E30_fiend
        • Apr 2006
        • 7348
        "Street demon"
        EBay
        Nuff said
        E30Fiend
        • VacMan
          • Apr 2007
          • 2405
          Google's got nothing on it that I can find, other than http://www.cmimports.co.uk/web-pages...cessories.html. Sounds scary to me.
          • monty
            • Feb 2007
            • 665
            Originally posted by abigballafb76
            "Street demon"
            EBay
            Nuff said
            E30Fiend
            This is correct, it ends in 10 minutes.
            http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
            • monty
              • Feb 2007
              • 665
              I dont know turbos exactly, this is why I ask questions.
              • monty
                • Feb 2007
                • 665
                They are selling the same kit with oil return lines for almost twice as much. They are selling the oil line kit for $90 in the accessories section. Something just doesnt jive.
                • SamE30e
                  • Sep 2007
                  • 4319
                  No, it just isn't a ball bearing turbo. They're very common on IHI's that came on volvo's, mustang svo's, mazdas etc they use a thin film of oil pressurized across the shaft as a bearing. It's common among turbos. If it's not ball bearing it's this.
                  1985 325e 2.8 Turbo VEMS
                  • mrsleeve
                    • Mar 2005
                    • 16387
                    yeah thats not the best set up I have seen. just you run of the mill Ebay crapola t3/t4
                    If you are going to go turbo GO GET A HOLSET Hx35 is just right.
                    Originally posted by Fusion
                    William Pitt-
                    • Jordan325iC
                      • Aug 2005
                      • 1697
                      Eh, it's more complete than most ebay kits I've seen. Still an ebay turbo kit. Be prepared to work to make everything fit.
                      '88 325is
                      BMWCCA 380364
                      • SamE30e
                        • Sep 2007
                        • 4319
                        Yea, who cares if you have to make it work, where else can you find a full kit like that for 1000$?
                        • NC325iC
                          • Mar 2004
                          • 6565
                          herro number one china turbo set here
                          • Jordan325iC
                            • Aug 2005
                            • 1697
                            Well, the turbo is junk and the manifold is prone to cracking. It's definitely a good start, but you will probably be replacing a few things a few months in. One or two people have tried it with success. You're going to need to spend at least another grand for the "little things" that are not included in that setup (injectors, clutch, gauges, wideband, engine management, downpipe+exhaust).
                            Still, $2k for a turbo setup is not bad. Comparatively, I built mine for $3k all said and done. Of course, mine is with a real turbo, oil lines and a sturdy manifold.
                            '88 325is
                            BMWCCA 380364
                            • backtrail69
                              • Jul 2005
                              • 4471
                              Don't do that to your car please. It is WAY too clean. If you are serious about turbos and e30s talk to Matt Kosonen or Ben R in Oly.
                              :: PNW Crew ::
                              '87 325 4dr, '74 2002
