vdo cluster
  • stormspike
    • 401
    vdo cluster
    Can you replace a Motometer cluster with a VDO one? I did not know if the pins were the same. Thanks!
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    Yes, the pins are the same. All you want to make sure is whether you get an early or late style cluster. Some of them have 3 red SI lights, and some only one. Those will not properly interchange as I understand.
    • James Crivellone
      Head Janitor
      • 6305
      Correct for all internal cluster parts.
      The old clusters will work fine, however the tach may read weird as the early 84/85 3SI light clusters were never designed for the m20b25 in the united states.
