off to the shop
    off to the shop
    well the cabrio made it to vegas but killed the clutch on the way. it still drives but makes one hell of a noise. so its off the the shop to get fixed.
    nice mudflaps!
      What did it sound like? Was it only when the pedal was depressed? Did it do it when you tried to start it?
      My 2.9L Build!
        it got to the point where it was making the noise if the clutch wasnt engaged. but yes it started only when the pedal was depressed then when u started it. i think it is the throw out bearing. but because of the problem it started to spin the clutch thus killing it too.
          oh and i like the mud flaps on this car for some reason.
            Looks clean
            ** Lot's of M20 turbo parts for sale.**
            Turn key track car.
            http://www.r3vlimited.com/board/showthread.php?t=222066
              Wanna See More Pictures>
              Originally posted by e30e
                input shaft bearing?
                1988 e30 alpine white vert 5speed
                1987 e30 325 eta
                1983 e28 533
                2001 x5 4.4l
                1997 e36 M3 Alpine white 5speed
                1991 Jeep XJ I6 4.0
                  Whats it doing in Vegas? On your way to Bimmerfest?
                    I just went through this and it was actually the pilot bearing that had pulled out of the crank. Squealed on startup and then got quite until I pushed the pedal down and then it went to screamin'. I know it sounds odd, but, it did happen. Took me like 5 hours to pull the tranny, clutch, and put it all back together.
                    My 2.9L Build!
                      yea the throw out bearing was locked up and the pilot bearing was screwed. plus they r replacing the rear output seal, shift seal, reverse light switch, guibo, trans monts, and pivot pin. so it will be straight when all is said and done.
                      More pics of the car can be found here http://www.r3vlimited.com/board/showthread.php?t=107468
                      I am in vegas for a friends wedding. my gf had never been across the country so i decided to drive.
                        Thats a hell of a drive. I have done it twice, once out and back.
                        While there goto Green Valley ranch to do any gambling or partying if you want to win something and to stay away from the tourist trap on the strip. Very cool place to hang at.
                          well the car is fixed. but it costsed all of my gamblin money, so i have only played a little. leaving tomorrow to drive it back home.
