Ethos Gas reformulator?
    Originally posted by 2Big4a3Series View Post
    I am waiting for the device that can double your milage by splitting the gasoline molecules in half.
    Fidhle007's M10 parsac module did that I believe...
      It was a Parsec Module, but only for m10 turbo cars.
        Yeah, but it only worked twelve times and then failed miserably.
        '89 325is S50 Track Montser
        '04 X5 Daily/Tow Vehicle
        http://www.avarestoration.com
        http://www.myspace.com/brendanfiddle
        Click here if you want to be my zombie slave...
        http://www.youtube.com/user/Fidhle007
          Come on guys. We all know that the only way to increase your mileage while adding high end output is by using the Vortex Valve (by going to www.vortexvalve.com ). It works because Indy 500 crew chief and "race engineer" Mark Weida sez so. (Maybe it's the same guy whos pro-ethos, just dragging his name through the thick thick mud?)
          My
          '90 325i
            Whatever happened to that guy who made a hydrogen fuel retro-fit for nearly every car out there?
            You ask? He was locked up...for a phony restraining order and various other stupidity. He was also declared insane..but the thing worked. Someone needs to buy his blueprints and make this retrofit.
            I don't doubt at all that the Ethos stuff works. Pretty much anything is an improvement over your current horse-piss gas. Experiment: Take any gas with high ethanol content and let it sit in your chainsaw for a season of non-running. You will find the carb diaphram is rotted. Now use normal gas...it burns better thus creating better efficiency and doesn't foul stuff up as bad. Seriously...you might as well soak your injectors in Karo syrup with the current gas. I guarantee if you used Valero/Exxon over BP you will see a performance and mileage increase. So why not combine it with something to help it further?? Why do you think that airplane gas is ethanol free?
            Eta dude. 8-)
              If you split a gasoline molecule in half it would no longer be gasoline.
              On myth busters the blew hydrogen gas straight in to the carburetor and the car ran fine. The only problem with hydrogen and other alternative fuel vehicles is that the energy required to create them makes them not worth the money. Until we stop burning fossil fuels to create electricity it's kinda pointless. I'm still convinced parallel hybrid technology mated with a small biodiesal engine is the most viable solution. And ethanol is to volatile to work in a jet engine. It needs to be of a lower octane and higher BTU's. There is a jet fuel alternative that is awaiting FAA approval though.
              www.gecoils.com
                Mr. Fusion. That is the answer.
                '74 2002 - Build blog at
                nomads2002.blogspot.com
                  Everyone knows that's just the flux capacitor with "Mr. Fusion" stenciled on.
                    But if you remember the scene from Part 3 when they were in the old west, they needed gasoline to get the car going. Mr. Fusion's only purpose was to operate the flux capcitor.
                    LOL! I knew someone would eventually catch that!
                      Where do I send my gas receipts to in order to get the gift certificates? Can your mom just put me on her list so I can get the $100 for gas? Got some track time coming up. :)
                        [quote=2Big4a3Series;1086068]But if you remember the scene from Part 3 when they were in the old west, they needed gasoline to get the car going. Mr. Fusion's only purpose was to operate the flux capcitor.
                        Dude I swear I didn't even realize that was a real scene from the movie! I thought that someone actually made that thing to look like the flux capacitor! I fail.
                          everybody knows this is what the flux capacitor looks like!
                            Yeah, but since it produces the 1.21 Jigawatts needed to run the flux capacitor then it should be pretty effective as a power source for an electric car. Not bad for tossing in some bananna peel, lettuce and leftover Coke.
                            :p
                              I believe that it was a beer can.
                                This thread is so awesome now!!
