alignment specs HELP!
  • Pull_Addict
    • Jan 2008
    • 250
    i recently installed my GCs and i was just wondering if anyone has the specs on their alignment. since i work at a dealer i thought it would be nice to just to the alignment there. turns out that the earliest BMW they have in the machine is the e36. i would really appreciate the help from any of you.
  • twistednut
    • Nov 2007
    • 272
    front
    camber -1.7 - -0.7
    toe .11 - .19
    caster 8.3 - 9.3
    total toe .22 - .38
    rear
    camber -2.8 - -1.8
    toe -.02 - .48
    total toe .35 - .58
    These numbers are allowable tolerances in degrees.
    Hope these are what you are looking for.
    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
    • mrsleeve
      • Mar 2005
      • 16387
      just set your front toe, its all you can do, unless you have camber plates an tabs in for the rear.
      do it at home all you need is a tape an some time. set the front 1/8 of inch closer togeather than the back of the tire.
      Originally posted by Fusion
      William Pitt-
