swaping steering wheels.
  • bimmer_E30
    • 5001
    allright guys its the time now for a Steering wheel upgrade, anyways where is the wires or the conection for the horn wires in the Mtech1 steering wheel
    Originally posted by e30e
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    There are no wires, the horn works through the metal contact ring
    • bimmer_E30
      • 5001
      ok so all what i have to do is take the old steering wheel with its crap and just bolt in the new (used) mtech1 .
      • Sean5294
        • Jan 2008
        • 515
        i just did the swap today. perfect fit works great and took about 5 minutes to do.
        • bimmer_E30
          • 5001
          allright man, i just dont have the right wrech for it.
          • eric (^__^)
            • 1409
            I really want the m tech II wheel
            Not that I care, of course.
            • NC325iC
              • Mar 2004
              • 6565
              then buy one
              • bimmer_E30
                • 5001
                lol^
                • DCColegrove
                  • 2748
                  Pop the cap (roundell) 22mm sockett.
                  • bimmer_E30
                    • 5001
                    oh ok . thanks man!
                    • DCColegrove
                      • 2748
                      oh ok . thanks man!
                      You're welcome.
                      • Car Addict
                        • Mar 2007
                        • 1100
                        not meaning to hijack but i am just to lazy to make a new thread what is the procedure to removing the 318is steering wheel i ask due to the airbag. i would prefer not having that go off while trying to remove it.
                        • RedHoodRidah
                          • Feb 2006
                          • 1096
                          Disconnect the battery for like 10 min to make sure all the power is out of it before you get pwned by a airbag. After that on the steering column right underneath there is a cover/cap just feel around for it and pop that out and unplug the plug thats on it. Once you have that settle feel around behind the steering wheel and you will find 2 hole close to the center of the wheels. Its a torx bit I believe a very small one(forgot the size) that will release the bag and then from there its straight forward.
                          92 Granite Silver Vert
                          M60B40 5spd
                          • GraphicRage
                            • Oct 2007
                            • 213
                            Geez, I got railed for starting a steering wheel thread a week or so ago! Anyhow, yeah, it's a very simple swap, I definitely did a "doh!" when I saw how easy it was.
                            Cranking the wheel off that's been on since 1985, on the other hand, was quite the chore...
                            • eric (^__^)
                              • 1409
                              Originally posted by NC325iC
                              then buy one
                              how much does the m tech II wheel cost?
