little help please
  • -Javier-
    • May 2007
    • 382
    little help please
    a friend of mine just got an 87 325es but his low head lights dont work but his high do work, what can be the problem ? what can i check for? thanks
  • backtrail69
    • Jul 2005
    • 4471
    Fuse, relay, headlight switch, turn signal stock, bulbs, wiring, connectors.....
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Turf1600
      • 9815
      Change the bulbs.
      • atomic
        • Jun 2007
        • 5691
        Also a test light and that Bentley manual (as mentioned to you before) at this point would be your friend to narrow down where the problem is from whats listed above (outside of swapping out bulbs to see if thats a fix)
        :up: :up:
        • george graves
          • 19996
          Both stopped at once? Relay.
          Originally posted by Matt-B
          • -Javier-
            • May 2007
            • 382
            yes
            • Danny
              • 14216
              Relay.
              • gazellebeigem3
                • Jun 2005
                • 3712
                fluid
                • george graves
                  • 19996
                  Relay or fuse. Find the relay (it's in the manual I think - or on the lid)
                  If it's the relay - pull it and replace with your high beam relay for the time being.
