Would either of the Magnaflow mufflers be a good fit?
  • dandingo
    • May 2008
    • 301
    I know, I know. This should be in the exhaust section but no one really goes there. I've asked a few questions there with minimal responses.
    Anyway, I've been looking for a Magnaflow dual-in dual-out and found a few that might work. I wanted to know if anyone's running them or if anyone knows if they'll be an easy weld by a muffler shop?
    Also, one's 2.25 and one's 2.5. I wasn't sure which would be better?
    Thanks for everyone's help!
  • SynSyx
    • Apr 2008
    • 542
    i cant answer your question but im in the exact same boat as you, so ill def be following along
    BavAuto ~ Bilstein ~ BBS ~ Scorpion ~ MarkD ~ Prolumen
    Have you hugged a corner today?
    '89 335iC (M30) - summer
    '17 Mazda3 - winter
    • trashcop 80s 80s
      • Jun 2004
      • 1130
      I have a Magnaflow single in, dual out. 2.5 inch without a cat. With a mostly stock M20, it is loud, but very mean sounding. I don't know the muffler's part number, but it fit in the stock muffler area very well. It has two metal hooks welded to it for the stock mounting points.
      • z31maniac
        • 17566
        Dual 2.5" exhaust on an M20 would be a bit large I would think.
        www.gutenparts.com
        • E30_fiend
          • Apr 2006
          • 7348
          Seeing as i exhaust is a measly 2 inches, the best weld on muffler would be the smaller inlet diameter one. And by the way, you don't need a dual in dual out muffler. Single in works just fine with a "y" pipe. That's what I did with my first attempt at exhaust. It wasn't loud enough, so I piped it 2.5 all the way back. Frees up a little more space and makes it sound mean as hell. 2.5 is a little large though. Every once in a while I'll get a few back fires. But I'll deal with that. Its a small price to pay for it to sound good.
          Back on subject, find a muffler with the tip or tips you like and don't worry about how many inlets it has. Even if it had a 3" inlet to the muffler, you could still realistically mount it with a "y" pipe. You would just need the dual part of the y to be 2.25 and the single part of the y to be 3 inches.
          So just find something you like. A good muffler shop can do anything you need.
          E30_Fiend
          • E30_fiend
            • Apr 2006
            • 7348
            I think he means he has single 2.5" piping all the way back with no cat to a single in DUAL out muffler.
            E30_Fiend
            • z31maniac
              • 17566
              ^Possibly, but in the original post he did say dual in dual out.
              www.gutenparts.com
              • E30_fiend
                • Apr 2006
                • 7348
                If it was 2.5 dual in the the new muffler would just have to slide over the stock exhaust. It IS a little big though. You're right. Unless he is piping new exhaust then 2.25 would be the way to go.
                E30_Fiend
                • T Verdier
                  • Aug 2007
                  • 2636
                  i have 2.5 dual in dual out with no cat it sounds kinda shitty and kinda racy at the same time. when i first start driving it sounds hella raspy and shity even down low but when it gets hot it s only raspy above 4k and sounds beafy
                  • dandingo
                    • May 2008
                    • 301
                    E30_Fiend
                    I wasn't sure what size the original piping is. That's why I posted both 2.25 and 2.5. I really wouldn't mind getting a single in with a Y-pipe, I just wasn't sure if it would be restrictive?? That's my main concern. I don't want to lose any HP or fuel economy just for sound.
                    And I do have a cat. Everything's stock, I just wanted a muffler.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      I ran a y for almost a year and had no problems. Noticed a difference in top end. Now I have a y at the exhaust manifolds and 2.5 all the way back. Its a nice setup. I have some I.E. long tube headers waiting to be installed.
                      E30_Fiend
                      • dandingo
                        • May 2008
                        • 301
                        E30_Fiend
                        I'm guessing it was a bad difference? So you lost a little power in the top end?
                        • dandingo
                          • May 2008
                          • 301
                          Anyone have any idea if the 2.25 would work if I brought it to my muffler shop and had them weld it up? I just want to make sure the stock piping will line up with the inlets on the muffler since they look a little wide.
                          • SynSyx
                            • Apr 2008
                            • 542
                            bump, i need the answer to this question as well
                            '17 Mazda3 - winter
                            • Emre
                              • Sep 2007
                              • 1228
                              Stock exhaust line diameter for a regular 325 is: 1.75" x2. So, even a dual 2" input muffler is a tiny bit big and will need some fabrication to fit properly and work well. Dual 2.5" is way too big.
                              To guys who think "bigger is better," remember that these are not f/i cars. With an n/a engine, intake and exhaust length, diameter, and tuning is critical. You need a diameter that's large enough to flow well, but narrow enough to promote good exhaust gas speeds (remember Bernouli's principle). Similarly, the total length of the intake-exhaust tract (from intake to exhaust tip) is just as important. As for a cross-over pipe, the placement is critical on an I6 engine: you need the exhaust pulses to be out-of-phase with each other.
                              You can't just use any tube diameter you want and stick a y-pipe anywhere you feel like it.
                              1987 Mercedes 190E 2.3-16: Vintage Racer
                              2010 BMW (E90) 335xi sedan: Grocery Getter
