Early front lower seat belt strap?
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Tags: None
ive runacross the same problem... thoughts?e30sport.net
'06 M3 Competition - 6-speed
'97 Range Rover Vitesse
The early model belts don't work with the late model receptacles? My late model belts work with my early model receptacles. I just figured they were both interchangeable.
How much did those late model receptacles run you from the dealer?- Trey
E90 325i/6 (ZSP, ZPP, ZCW)
E36 325i sedan
E30 325i sedan
Volvo 945T
Originally posted by TDE30 View PostThe early model belts don't work with the late model receptacles? My late model belts work with my early model receptacles. I just figured they were both interchangeable.
They were about 70 for a pair from blunttechenterprises.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Once I have more info on this I'll post the right PNs...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Early ones are not available.
So, I am going to see what it will take to install 89 belts into my 84 318i instead....Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Jean,
I have a complete set of seat belts from a 91, minus the driver clip. Let me know if you are interested. They are in great shape.sigpic
Levent
%20levent@gutenparts.com
Ladies:
Originally posted by equate975 View PostFUCK I knew there was something I forgot to order from blunt lol. My pass side is completely shot, and the driver side will only latch if you push the button down first.
Maybe go to the stealer and see if they can look it up? Might know something realoem doesn't.
No, mobile tradition won't even help in this case. So, SOL.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by ZM Blue Devil View PostJean,
I have a complete set of seat belts from a 91, minus the driver clip. Let me know if you are interested. They are in great shape.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
So I just took the front belts off my 89 325i car and swapped them into my 83 318i along with the seatbelt recepticles. So they swap right over for those who are wondering.
No modifications needed.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
No, all tight. Did it have all the washers and plastic hardware on the long bolt ?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by Jean View PostNo, all tight. Did it have all the washers and plastic hardware on the long bolt ?- Trey
E36 325i sedan
E30 325i sedan
Volvo 945T
