Burnt smell when A/C is on
  • catchuk
    • Jan 2008
    • 344
    Who has has this happen to them before? At first I thought it might be refridgerant, but I didnt smell it coming out of the vents. When i got close to the HVAC panel i smell it there, has this happened to anyone? nothing came up on a search, i was thinking maybe it was the A/C switch? anyone with any onfo?
    thanks
  • txleadfoot
    • Apr 2006
    • 208
    my a/c clutch fried to a crisp last summer. did you check for smoke in the engine compartment.
    • catchuk
      • Jan 2008
      • 344
      No I didnt, ill def take a look! thanks
      • george graves
        • 19996
        Did it smell like a turd caught on fire? Yes?
        Yea, it's your belt. It wore out. $10 and a wrench and you are good.
        Originally posted by Matt-B
        • catchuk
          • Jan 2008
          • 344
          it wasnt a belt smell, the a/c actually works great, it actually smelled like a couple of wires melting
          • emi325i
            • Oct 2006
            • 356
            check your fuse box.. mine melted when running the blower on hi/4
            • Kruzen
              • Mar 2004
              • 5603
              I've smelled burning like this before, never figured out what it was because all my shit works fine.
              Who doesn't love a little BBQ?
              Griot's Garage at a Deep Discount
              • Coco Savage
                • Sep 2007
                • 1039
                had a problem and found someone with similiar prob...dont know if this is whats wrong with you.
                But a/c on..all of a sudden burnt smell and smoke comes out of dash. Smell was wires melting....after replacing blower problem was gone. I have heard some just cleaned their blower fans and it took care of problem...
                Not sure if thats whats wrong with you
                • catchuk
                  • Jan 2008
                  • 344
                  i only have the smell when the a/c is on, i was kinda thinking a refridgreant leak but the a/c still works great and the smell is not coming from the vents.
                  • Coco Savage
                    • Sep 2007
                    • 1039
                    i noted that the burnt smell came about when the a/c was on only.....but if you dont think thats it.....was just a fyi
                    • catchuk
                      • Jan 2008
                      • 344
                      Update:
                      Well, Its definitely an electrical problem and the smell was from some melting wires. Today the smell sort of subsided, all was good, but then out of no where, I smelled it again and I looked down and there was smoke coming from th HVAC unit. Ill be pulling out the HVAC to inpect it and the blower motor.
                      Thanks to all who posted,
                      nick
                      • Coco Savage
                        • Sep 2007
                        • 1039
                        exactly what i posted earlier.... Blah to all that mess
                        • Skoobeesnak
                          • Jun 2006
                          • 132
                          AC no worky
                          Mine did the same thing a few years ago and it wasn't until last fall I took the dash apart and saw the partially melted wires. Based on something I read on here I wired them together and nothing changed. So now I either didn't fix that problem or the system has lost its freon from sitting for so long. Oh and it is around 100 degrees today in my black on black '87 325is. Good times. Any advice on what to check first or next? Much appreciated.
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            Check your freon.
                            Does your compressor kick on?
                            Hows the dryer?
                            That should keep you busy.
                            Yours truly,
                            Rich
                            you kids get off my lawn.....
