Question: Will this break? (Ireland Engineering content)
  • maniacmatt
    • Feb 2007
    • 483
    #46
    Originally posted by Aptyp
    Hey, matt.
    Help a brotha out, I need a cheap welder for home use, know what's good? How much is good? I'm too dependent on school welder, but i got projects at home too.
    Like anything you will get what you pay for. Buy a cheap welder you will likely have nothing but problems. My experience is mostly with lincoln and Miller machines, but any machine from Miller, Lincoln, ESAB, or even Hobart should be pretty good. I have found that for small machines that run on standard household power lincoln makes a better machine than miller.
    My advice to you though would be wait around and do it right. If you plan on doing anything serious at home save up your money get some industrial power (240V or better) wired into your garage and buy a nice multi-process machine. I cannot stress what a huge difference the type of power makes for a welder. I have a small 20% duty cycle lincoln wire feed welder at home and honestly I hardly ever use it, I find it easier to run 15-20 minutes to the shop I work at and use their TIG welder.
    Picking a welder is so subjective though it all depends on what you want to do with it, how often you will use it, and what kind of result you are looking for.
    Personally though I will never again buy a small wire feed welder like that for home. I currently have my eyes set on a Miller Dynasty350 with TIGRunner package. But that is something you will have to use alot to justify buying. TIG is the way to go as far as I am concerned, Change out the tungsten and the filler rod and you can weld anything you like. If you know how to use it it will also yeild the best results by a mile.
    How aften and for what are you planning to use this welder? Just knowing that will help narrow down what kind of machine will work best for you.
    • PiercedE30
      • Apr 2005
      • 4220
      #47
      Awesome forum dedicated to welding.
      My 2.9L Build!
      • kowalski
        • Jan 2005
        • 1791
        #48
        Originally posted by DSP74
        People can burn IE down for all I care. But come on this is a fuckin sway bar....If it makes you feel better grind the tab off and re-weld it yourself when you get it.
        Not like there are other options for a 25mm bar.
        generally when you buy parts specifically for a car, you expect to NOT have to reweld and modify things, unless your buying cheap Chinese shit.
        • 318isbmw
          • Nov 2005
          • 2843
          #49
          +1 that's the theory I live by also. Parts aren't cheap so I like em to stay together.
          The springs are fine, but have the normal issues w/ the reverse rake look. But work fine.
          • DSP74
            • Nov 2007
            • 1121
            #50
            Agree 100%
            Now show me that other 25mm front bar for an E30
            88 325is
            • kowalski
              • Jan 2005
              • 1791
              #51
              Agree 100%
              just because they're the only one with a 25mm bar, does not mean we don't have the right to call their product, and their company shit. I can start making a 25mm bar, but I'm not going to take the time to bend it, or make it properly. I'm just going to ship you a 25mm piece of round stock, and you can make it fit from there. Now we've got 2 25mm bars, How does that sound?
              • DSP74
                • Nov 2007
                • 1121
                #52
                Learn how to read. I said I don't give a shit about I/E.
                Make a 25mm bar and sell it. Until then there is only 1 place to buy one.....Ok two. IE, and Flying Brick, which is an IE part.
                88 325is
                • Aptyp
                  • 6584
                  #53
                  So Miller 180 it is.
                  As far as the sway bar goes, mine is still holding up just fine.
