Fast Setting automotive epoxy?
  • AdironRider
    • Dec 2004
    • 3491
    Need a quick answer so Im posting in general...
    I backed my Jeep out of a garage in a rush and broke off one of the side mirrors. Its a Jeep, so I dont want to spend to much money and dont care how it looks, I just need a fast setting, strong epoxy to hold the thing on and pass inspection. Mirror isnt the lightest. Any suggestions? Its a plastic on plastic "bond", so it needs to be able to work on that. Thanks.
    Back to my roots
  • PiercedE30
    • Apr 2005
    • 4220
    JB Kwik
    My 2.9L Build!
    • der affe
      Technical
      • Dec 2005
      • 8452
      no. it wont stick to the plastic mirror ^^^^^^^^
      go to an automotive paint supply and get some panel bond. it is a 2 part epoxy we use to "glue"? metal to metal. it had different drying times choose the one with enough time to position it where you want it to go.
      it is usually black too so it should blend in with the plastic.
      • ddavidv
        • 344
        Tough to glue.
        Used mirror, FTW if you ask me.
        • SamE30e
          • Sep 2007
          • 4319
          Duct tape.
          1985 325e 2.8 Turbo VEMS
          • Jand3rson
            • 37587
            Zip ties. For cereal.
            • Turf1600
              • 9815
              semen
              • RedHoodRidah
                • Feb 2006
                • 1096
                Originally posted by Turf1600
                semen
                x2 I made a headgasket, oil pan gasket and motor mount out of it nearly 3 years ago and its still holding with no leaks or signs of wear.
                92 Granite Silver Vert
                M60B40 5spd
                • e34john
                  • Apr 2006
                  • 3599
                  Go to a craft store for acrylic glue or plastic adhesive, It will melt the two pieces back together. Or find a place that has Weld On. Look up plastics in the yellow pages for retailers.
                  • bmw325csi
                    • May 2007
                    • 4045
                    Grab a torch, melt both parts, stick it on, cool it off with some ice water, voila.
                    harry/harout
                    • Jonathan Chan
                      • Jan 2004
                      • 93
                      You can also just grab some 5 minute modeling epoxy (or automotive epoxy) from Pep Boys, etc...
                      I think the quickest setting is 5 minutes, and it comes in 2 parts that you need to mix.
