Olds Aurora AC Comp...
  • SpecM
    • Oct 2005
    • 4531
    -My dad has a '98 Old Aurora (4.0 v8 ) and the A/C compressor ate it. I am 90% sure that on many Caddys with Northstars, the engine has to be removed to replace the A/C comp. Now, the v8 in the Aurora is basicly a narrow-bore Northstar... so...
    ...Does the engine have to be removed to replace the A/C comp on a first-gen Olds Aurora? Need to know cuz... well, I've been chosen for the task.
    PS: NO FWD American car flaming, please. Its actually not a bad car.
    1989 cirrisblau-metallic 325i
  • StereoInstaller1
    GAS
    • 22679
    nope, no flamings, just wondering why you haven't jacked it to power the E30.
    Closing SOON!
    Thanks for 10 years of fun!
    • SpecM
      • Oct 2005
      • 4531
      -Haha don't think it hasn't crossed my mind... 250 hp ftw
      • StereoInstaller1
        GAS
        • 22679
        Lighter than an M20, I would guess.
        Closing SOON!
        • SpecM
          • Oct 2005
          • 4531
          -Yeah or about the same. Alum block, 32v, DOHC, blah blah blah. Block design is baced on the small block Chevy, iirc, so if you can swap an LS1 you can swap a Northstar.
          -So... about that compressor...
          • StereoInstaller1
            GAS
            • 22679
            I got nothing for ya, sorry.
            Closing SOON!
            • Jand3rson
              • 37587
              There was a guy in Eurotuner a few years back that put a 32V Northstar in a MkII Golf. It was pretty badass. Automatic, but faster than most of the stuff around here!
              • RedStar240
                • Mar 2007
                • 769
                Yeah that might be pretty sweet.
                Benji
                '90 M50 + M3 Tranny e30 - SOLD
                '99 528iT (M5 Rep bumper) - SOLD
                '03 ML350 - For Sale
                BIMMERLESS at the moment. :???:
                • kroberts
                  • 680
                  Spec, I posted your question on a firearms forum I belong to (30k members). I may have an answer for you pretty soon. I'll let you know.
                  I have heard some crazy shit about Northstar V8 work before. One example, the starter is under the intake manifold on Caddy Northstars. Engine removal is required to change them. I dont know firsthand if this is true, just what I had heard. That is some dumbass engineering IMHO. like the old V8 powered Chevy Monzas in the early 80's. The #7 and #8 spark plugs were so far up under the firewall, you had to nearly remove the engine to change them.
                  • SpecM
                    • Oct 2005
                    • 4531
                    -I saw that, I would definatly rock it!
                    -OK... update... looks like I wouldn't have to pull the compressor. The clutch will kick on and turn but the compressor isn't turning over, the shaft doesn't move and the engine doesn't load up. GM sell a "clutch facing" ($151!) which should fix this. I can borrow a small puller and replace it w/o pulling the compressor!
                    -But I'm still curious about it...
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      Well, partially true. The starter IS under the intake manifold, but its a composite manifold with reusable gaskets held down with four top-accessible bolts. I'd rather do starters in those all day than one in an e30. Toyota also hid starters in there in the Land Crushers, but that was a two piece manifold with 3 million bolts holding it on.
                      Check out www.cadillacowners.com they have a TON of Northstar info. I'm even a mod there.
                      -Dave
                      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                      Need some help figuring out the ETM?
                      • SpecM
                        • Oct 2005
                        • 4531
                        +1 the mani is easy to get off a Northstar
                        • kroberts
                          • 680
                          Well evidently none of my "brothers-in-arms" has an answer for me over there. One dumbass posted a link to the Autozone site. Sorry.
