Euro filler installation
  • KillaCams
    • Mar 2008
    • 998
    I just got my filler from Abrahams and want to install it. It needs to be drilled, but i want to be careful before i fck it up. Anyone have any tips on drilling this or can share with me how they did this neatly?
    From what i see i can do 2 things:
    1 - Use the US license plate as a template - Don't really like that option
    2- Measure where the holes are on the car, match said measurements to the euro filler and then drill.
    I really don't want a bunch of holes in this if i fck up so any help is greatly appreciated.
    Thanks,
    -Azad
  • Van Westervelt
    • 9365
    I just popped out the grommets on the body for the plate screws, and mocked the filler up. Then from inside the trunk, I marked the back of the filler with a pen or a screwdriver etc.
    I only did the top ones, that way I can run a euro plate in rear and not have holes exposed.
    • KillaCams
      • Mar 2008
      • 998
      Great suggestion, ill post some pics when i finish. I was afraid of drilling it and it wouldn't line up the way it should. I'll also only do the top holes. Thanks so much for the input.
      -Azad
      • Aptyp
        • 6584
        hm, good one.
        • ZM Blue Devil
          • Dec 2006
          • 13836
          I did almost the same thing, with a slight difference. I cut the plastic caps tops off so they have a lower profile otherwise the filler sticks out too much. I put all 4 back in(even though I didnt use the bottom ones, so no water gets in from the bottom holes). with the tops cutoff the fit comes out nicer.
          Levent
          %20levent@gutenparts.com
          Ladies:
          • Van Westervelt
            • 9365
            Thats not that good of an idea as the filler will then rub through the paint in areas. As me how I know. :) You need that lil bit of space, and mine is flush with the tails.
            • ZM Blue Devil
              • Dec 2006
              • 13836
              nope, still not touching, left just enough, but yes you are right if you mount flush it will rub the paint.
              Levent
              Ladies:
              • scabzzzz
                Estado de mierda de encargo
                • 6871
                I just lined it up and took a guess. Only messed up once. Who cares though. It will always be covered up anyways.
                • KillaCams
                  • Mar 2008
                  • 998
                  I'm not sure i like the way the fitment came out, it's kinda sticking out a little more than i want it too...
                  From far away it looks fine but when i get really close to it i can see it's not as neat as i want it, maybe im being overly anal. Let me know what you guys think about the fitment and how it compares to yours:
                  • Bimmerista
                    • Nov 2005
                    • 5425
                    ^ Yours looks fine
                    Here is mine:
