Timing belt replacement question
  • ainadude
    • Apr 2008
    • 221
    I'm trying to complete a timing belt replacement and have run into the following snag: When I've got the belt and tensioner on with both crank and cam lobes in the proper positions, I end up with a little slack -- maybe a couple of degrees -- when I rotate the crank by hand. A friend of mine who's helping -- and says he's done the job several times -- insists there should be absolutely zero slack, that the cam should move at the same instant as the crank. Is this correct? I've checked a couple of online "how-to's' and haven't found any mention either way.
    ainadude
    Indian Wells, CA
    1991 325i 2dr. 5sp, delphin, w/freshly re-skinned IS sport seats/15" Ronal cross-spokes
    1976 Triumph Spitfire w/1.8-liter Miata engine/transmission, koa dash with TR6 oil/volt gauges, lowered suspension, 14" Minilite replicas and more
    2004 Kawasaki ZZR600
  • StereoInstaller1
    GAS
    • 22679
    Are you aligning with the timing cover marks or the notch near the crankshaft?
    If you look at the crankshaft cover (the PITA around the timing belt) you will see a notch. Use that notch instead of the crankshaft pulley, you will have an easier time removing the slack.
    Closing SOON!
    Thanks for 10 years of fun!
    • Dave
      E30 RAT
      • 11675
      silly question - did you tension it?
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • funcrew
        • Jun 2007
        • 1223
        Exactly. Did you let the tension spring put the correct tension on the Tbelt and then tighten the tensioner in that position?
        "If the sky were to fall tomorrow, the tall would die first."
        -Dr. Paul Forrester
        Do I LOOK like I need a psychological evaluation???
        • joshh
          • Aug 2004
          • 6195
          It shouldn't have any slack...
          "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
          ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
          • SpecM
            • Oct 2005
            • 4531
            +1 zero slack. Make sure you let the tension up on the driver's side, not the pass.
            1989 cirrisblau-metallic 325i
            • StereoInstaller1
              GAS
              • 22679
              This is why you need to make sure and NOT follow the Bentley; it is clearly wrong.
              Try it my way and you will see the obvious logic behind it, plus the tension will actually make sense.
              Closing SOON!
