i'm missing the fuel injector tip!
  • eshghehBMW
    • 162
    i got 1 injector that is missing the very tip ( not the metal but the plastic cover)...
    Is it ok to use?
  • bmw325csi
    • May 2007
    • 4045
    Well if the O rings are still there it should be fine. IMHO
    harry/harout
    • eshghehBMW
      • 162
      yes the rings are there and in good condition.
      • bmw325csi
        • May 2007
        • 4045
        Yeah then. you should be fine.
        harry/harout
        • rs4pro3
          • 5808
          um, no you need the cap, you can pick them up at napa for a few bucks, ask for pintle caps for a 90 mustang
          85 325e 2.7 ITB'd stroker
          • eshghehBMW
            • 162
            Um no...is kinda vague...but maybe u don't know.
            Anyway, I already put it that way and I already bolted on the manifold so we'll find out soon enough
            • SpecM
              • Oct 2005
              • 4531
              -How was his comment vauge?
              1989 cirrisblau-metallic 325i
              • mattdk318i
                • Jun 2006
                • 3953
                • rs4pro3
                  • 5808
                  The cap serves a purpose, and helps keep the o-ring in place to seal the injector, and also directs the spray from the injector somewhat. Without it you are going to have a very high chance of a vacuum leak.
                  • eshghehBMW
                    • 162
                    thank you very much...that's much better.
                    I did have the ring there so it's sitting in, nice and snug.
                    Anyway...I put everything back today (silly injector included)
                    what I did was replace my head gasket
                    and I put everything back right (at least I think)
                    However, the car does not turn on right now...but it does turn over...
                    I didn't put on my air filter or anything yet...Also I smell gas but I'm not sure if the pump has pumped enough into the injector's line...
                    what should I do to properly bring her back to life???
                    • einstein57
                      • Jun 2007
                      • 10780
                      You can still swap out the injectors with the manifold on there.
                      www.gecoils.com
                      • eshghehBMW
                        • 162
                        Please Please...tell me how. (in detail please)
                        PS any idea why it's not turning on right now?!
                        • SpecM
                          • Oct 2005
                          • 4531
                          -There's no big fancy procedure to swaping injectors with the manifold on. Take off the valve cover for more room!
                          • einstein57
                            • Jun 2007
                            • 10780
                            remove hoses from valve cover
                            remove valve cover
                            remove fuel rail
                            pop out injectors
                            Took me about 30 minutes to do it. (i'm kinda slow)
                            www.gecoils.com
                            • maco325e
                              • May 2007
                              • 177
                              Thats what I put on '85 when I rebuilt my injectors, mustang injector rebuilt kit it's a perfect fit. I even have the '90 mustang O2 sensor in my car.
