Quick exhaust question
  • 87e30
    • Jul 2008
    • 5676
    Okay guys, I'm sorry that this is a complete noob question. I've searched and looked around a bit.
    Will an i or is exhaust fit on an e or es?
    I have an 87 325es and I need an exhaust looking to pick up an i exhaust locally.
    Edit: Sorry this is in the wrong spot.
    I just hate everyone.
    No need for discretion.
  • kid325e
    • Sep 2007
    • 6421
    i have an 87 eta and i have no exhaust from the cat back. I picked up an IS catback stock exhaust and found out that you would need to fabricate a Y pipe to get the I exhaust to mount up to the E exhaust. Dual Downpipe on the IS vs. the Single downpipe on the E.
    Hope this doesn't confuse you more..
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • ethree
      • Aug 2007
      • 1213
      You need the whole thing, it isn't easy to interchange parts from either system but if you have the whole system from the manifold to the muffler you shouldn't run into any problems.
      • T Verdier
        • Aug 2007
        • 2636
        no
        • Danny
          • 14216
          Originally posted by T Verdier
          no
          Wrong.
          Fab up a Y pipe.
          You can make it fit.
          • AndrewBird
            The Mad Scientist
            • 11898
            The exhaust manifolds are the same, but everything else is different.
            Going to an i exhaust should be a slight upgrade.
            • James Crivellone
              Head Janitor
              • 6301
              The I manifolds are actually a little larger (the runners themselves anyway, externally they appear to be the same)
              If you check ETK, they have different part numbers, and the I manifolds cost twice as much.
              Either way, an I exhaust would produce a slightly nicer noise.
