Alternator R&R - WTF?
  • E30 Cabrio
    • Oct 2006
    • 1954
    Who the hell designed this?
    My alternator belt is a bit loose and I wanted to tighten it up.
    The top adjuster is accessible, but the bottom bolt, forget it.
    The Bentley isn't much help either.
    Do I have to remove the PS pump from below to get to the bolt to loosen the alternator?
    Also, what size is that bolt?
    1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
    Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
    Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
  • Schneider325
    • May 2004
    • 3818
    13mm wrench, sideways on the bolt. Make sure you have another 13mm on the ‘easy to get to’ side.
    • Jean
      • 18228
      ^ what he said. It's much easier on the 318i too :)
      • E30 Cabrio
        • Oct 2006
        • 1954
        I can't even see the bottom bolt from the top or the bottom. The PS Pump is in the way from the bottom, and that is with the car jacked up.
        And, which side is the "easy" side?
        • Schneider325
          • May 2004
          • 3818
          It's there, check out realoem for reference
          • E30 Cabrio
            • Oct 2006
            • 1954
            I did. Still can't see it.
            • kowalski
              • Jan 2005
              • 1791
              its pretty hard not to find... use your hand to feel where the bolt is, then put a wrench on it...
              • TwoJ's
                • Oct 2005
                • 4908
                What he ^^ said. It's really pretty easy...
