Fuse 6 short help needed
  • mundtquist
    • Sep 2007
    • 94
    Hi,
    I have a dead short that keeps blowing fuse #6 (brake lights, cruise, ABS, Active Check Control and interior lights). I disconnected the brake light switch and the fuse still blew. Any other ideas or advice on tracking this down? I can run a fused line to the brake switch so I can drive it, but I want to fix it correctly.
    The car is an 89 325i that is just coming to life after a light rebuild. I removed the interior to weld in floor repairs, but did not touch anything on fuse #6.
    Thanks,
    Steve
  • equate975
    • Jun 2004
    • 3382
    Probably going to have to trace the line to see what shorted. I would guess some insulation heated up where you were welding.
    Either that or bypass everything on that fuse to see which component is shorting it.
    Where in MN are you?
    Rollin' with a Geistkuchen
