So everything is ordered and on its way, except.....exhaust
  • James Crivellone
    Head Janitor
    • 6305
    So I just finished ordering all the parts for my car, and now i need to start thinking about exhaust, first off i am putting the following parts on the car
    E30 M3 Steering Rack with new Tie Rods
    E30 M3 Rear Sway Bar with new bushings
    E30 Cabrio Front Sway bar with new bushings
    5 Speed Pedal Assembly
    Getrag 260 Manual Transmission
    Lightened Dual Mass ETA Flywheel
    New Clutch Assembly
    M Coupe Short Shifter with rebuilt shifting linkage
    1989 325I driveshaft
    3.25LS Differential
    M Coupe Differential Cover
    M20B25 Exhaust Manfolds
    Urethane Rear Subframe Bushings
    Urethane Rear Trailing Arm Bushings
    E46 M3 Cabrio Rear Shock Mounts
    Stainless Steel Brakelines
    ATE SuperBlue Fluid
    Redline Diff and Transmission Fluid
    Sparco front strut tower brace
    TONS of random nuts, bolts, bushings, etc
    So I have a front downpipe that I got from jordan, however my dad, being a 911 guy who really wants something to do on cars, decided to buy me exhaust.
    So I come here, asking for advise on what exhaust system I should run, I would like it to be compatible with a 2.8L Stroker motor, and keep in mind it will be swapped out when I do the turbo anyway. on the muffler I want straight pipes, none of that bent tip crap, and I don't want to run my dad into the poor house, so keep it somewhat inexpensive but good sounding, (i mean hell, its only lasting 2 years max in the car)
  • Brian 89 325i
    • 1450
    Id say get somthing bent up at the local shop, LOTS cheaper than ANY quality aftermarked system, that way you wont freak out when you swap it out. Id say a single 2.5" all the way back into a 1 in 2 out muffler.
    Brian
    • TheyCallMeDale
      • 321
      two years you say, get an ansa from bavarian. Theyre cheap and wont last longer than that most likely. Plus they sound pretty decent. Pretty quiet but aggresive when you get on it
      • LikeCDoos
        • Jan 2004
        • 2522
        I can get deals on all Magnaflow mufflers/tips. Let me know if you want me to check prices for you.
          • 37834
          Brian
          That's a perfect plan, do that James. And you could even get a muffler through Weston, Magnaflow for the most part sounds awesome with our motors.
          Grover Beach, California
          BimmerHeads.com
          • e30Matt
            • 5077
            What kind of deals can you get? Say on a setup like Jamie has?
            • F|2eeSTy|e
              • 372
              I may be interested too if you can gets deals 8)
              Brandon
              • rwh11385
                lance_entities
                • 18403
                Holy fuck, nice list.
                I think Ryan Stewart needs to get the S-fitty in his car before yours takes place in my mind as most kickass early model!
                • Xmarksthespot21
                  • Jun 2004
                  • 285
                  James,
                  Did you get a used e30 m3 steering rack or a rebuilt? and for how much?
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Originally posted by Xmarksthespot21
                    James,
                    used, 80K miles, 200 bucks
                    • LikeCDoos
                      • Jan 2004
                      • 2522
                      Guys go on magnaflow's website and get part numbers for whatever you would like...then i'll see how much i can get them for.
                      • e30Matt
                        • 5077
                        #14815 and #14816.
                        • James Crivellone
                          Head Janitor
                          • 6305
                          #14815 and #14816.
                          same!
                          are these mufflers dual in or single in?
                          • LikeCDoos
                            • Jan 2004
                            • 2522
                            #14815 and #14816.
                            same!
                            the one jamie has is single in dual out...magnaflow makes lots of applications though. I'm checking on pricing, i will get back to you later today or tomorrow.
                            • James Crivellone
                              Head Janitor
                              • 6305
                              #14815 and #14816.
                              same!
                              If i can get dual in I would like it, I ran across a 325i exhaust so I just want to replace the muffler
