Eibach springs right?
  • Hallen
    • 1008
    Yep, they are soft and the do lower the car a lot. I suspect these springs are a lot of the reason why people have problems with broken oil pans. You can't go over a moderate speed bump with those things and not hit the bottom of the car unless you just creep over the bump.
    When I changed out the Eibach Pro's on my car and put on H&R Race springs, the ride height didn't change much at all, but the Race springs are a much higher spring rate. That low spring rate on the Eibach's plus their short profile equals a higher potential for ground contact with the pan (in my opinion).
    1987 E30 325is
    1999 E46 323i
    RIP 1994 E32 740iL
    oo=[][]=oo
    • Aptyp
      • 6584
      I actually loved them on my DD. Unfortunately, they are just for looks. Car looks great lowered, and ride quality stays pretty much the same.
      • //MPower
        • Jun 2007
        • 182
        Pro-Kit = too soft
        | Jimmy | 1999 M3 | 1986 325 ES |
        • kronus
          • Apr 2008
          • 13028
          I have them. They're soft, yes, but they lower the car decently and are a good DD spring.
          cars beep boop
          • aworthybrother
            • May 2007
            • 899
            Ive been debating if I want to go lower from my H&R sport to something like H&R race / IE 3 / Eibach pro kit. I like the my ride quality now but thinking of going lower for the looks but do not want to sacrifice the ride quality and have stiff and harsh ride for DD.
            From what I read, H&R Race or IE3 is best and Eibach Prokit is soft....Does it mean Eibach=Soft is compfortable? What are the chances of hitting the ground specially in the NY/NJ roads?
            I would like to hear your suggestions please.
            • brandondan1
              • 1091
              I run eibachs with bilstein sports, and the ride quality is ok.
              Cons:
              Car doesn't absorb bumps nearly as well as stock suspension, and on rough roads it almost feels like you're galloping on a horse.
              Noise over potholes increased a lot as well, and it feels like you're fking something up everytime you roll over one.
              The extra roughness isn't good for your electronics, and if there's anything remotely loose in your car, you'll hear it.
              You need to creep over speedbumps to avoid hitting the bottom of the car.
              If you get a flat, you'll need a LOW profile jack to raise the car up.
              Negative camber wear on your tires
              Pros:
              Car does feel more planted in turns.
              Stance looks good.
              I'm honestly thinking about switching to H&R sports since this is my daily driver.
              91 318is
              • MG325i
                • Jan 2007
                • 805
                just like everyone just said, very soft springs but nice for a DD with Bilstein Sports. Which is what im running on. Sig shows ride height. Course, running 15's instead of 16's might help make it a smoother ride?
                E30 325I > SOLD
                E30 318IS > SOLD
                E39 530I > SOLD
                EP3 > SOLD
                95 M3 > SOLD
                97 M3 > DD
                • 92 mtechnic cabrio
                  • 4907
                  Eibach's springs are usually red, you know there's something wrong with a company's product line when they don't even make them the company's signature color........like they don't back up their own product.
                  R.I.P 07/01/09 - 04/23/10 :(
