Windows not going down.. help.
  • lespaul
    • Jul 2008
    • 121
    I had a bunch of tires in my front seat, and after I removed them, the windows wouldn't go down. I'm only mentioning that because the glove box is loose, and I don't know if the tires pushed anything behind the glove box that screwed up the electrical. All four buttons don't respond. Any thoughts?
  • kronus
    • Apr 2008
    • 13031
    There's an unmarked button either in your dash next to the emergency blinkers button or in the console, above the window switches. Push it, it should make a clicky sound.
    (that's the window breaker switch)
    cars beep boop
    • slo325i
      • 417
      Is there a fuse for them?? I'd check there first
      '89 325i - Totaled... good bye my love...
      '87 327i budget stroker - SOLD!!!
      '92 240sx - ca18det powered drift toy - SOLD!!!
      '89 325i - coupe - NEW daily
      '96 Audi A6 Quattro- Grocery getter/baby hauler
      '99 Busa - weekend wheelie monster
      • lespaul
        • Jul 2008
        • 121
        I checked the fuses they are good, and the button doesn't do anything. hmmmmmmmmmmm....
        • Eric Giles
          • 1068
          Double and triple check that large, unmarked button again-on your car it should be on the center console to the right of the shifter. If you see a red band at the base, then that circuit breaker has the windows set to off. Press it down (they get sticky over time) until you don't see the red band and the windows should work again.
          I am pretty certain one of the tires you were hauling pressed down on that circuit breaker.
          Eric Giles
          '20 M2 CS
          '04 M3
          '11 X5 35D
          '87 325is
          '91 325i Sport
          There are few things more expensive than a cheap BMW...
          • lespaul
            • Jul 2008
            • 121
            Well I pressed it multiple times. Then I opened up the center console, and noticed that there are NO wires connected to that button! The windows were working flawlessly this morning.. argh.. Not sure what to do from here.
