major water leak, passenger and drivers
  • new2bmw
    • Oct 2006
    • 387
    so i am driving 2 hours home tonight in a rain storm when i feel water dripping onto my left foot, right near the drivers side speaker, i then ask my wife to feel the floor by her feet and sure enough it was soaked. By the time we got home the drivers footwell was very wet and the passengers was full of water almost an inch above the carpet. the wetness starts at about speaker height and goes no higher.
    Any ideas guys, i need to find this and then run a dehumidifier in the car for a few days once it is fixed.
    thanks for any help on this one!
    cheers
  • E30 Cabrio
    • Oct 2006
    • 1954
    Sunroof drain tubes are probably clogged. They're also made of plastic, so if they are cracked/broken, they will leak inside the car.
    Take a piece of cable, like you use for TV and cut off the connector on the end.
    Retract the sunroof and find the drain holes and push the cable into the drain holes to clear them.
    I believe the fronts drain thru the plastic grill area behind the hood, and the rears drain thru holes in the trunk.
    At least that's the way I remember it on my 86 325es
    Check those front drain areas, where the plastic grills are to see if they are full of leaves, pine needles, any thing else that would prevent drainage and overflow/leaking.
    1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
    Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
    Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
    • hendrixvodu
      • Jan 2007
      • 2514
      there is also a drain this is usually clogged on every e30 if you look at your battery tray under the hood its on your fire wall right near that, its like a black plastic or rubber elephant trunk style thing
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • Jparkr
        HR Admin
        • Jan 2006
        • 3494
        wanna know how i found that?
        1987 PRO-3 car /1990 325is (2.7i Concours)
        • new2bmw
          • Oct 2006
          • 387
          ok not sure
          i took the front speakers out and found a drainage tube behind there, when i wiggle the tube it sounds loose and like it leads up to the sunroof. i am worried that there is no connection of the tube to the sunroof. i poured some water down the sunrrof drain and it came out near the front of the door from under the rockers.
          if the tube was not attached would the water just drain into the space behind the speaker and then find its way out of the bottom drain holes? i looked on realoem and couldnt find any pictures of the drains in our cars. if anybody has any could you post them please?
          thanks guys
          • ethirtydavid
            • Jan 2008
            • 2331
            Originally posted by Jparkr
            ahaha
            • direction88
              • Feb 2007
              • 228
              Could someone post some pics of the drain locations? The linked thread is full of red Xs.
              "Drifting an E30 is like pouring out a beer just to get a nickel for the can"
              • mikeedler
                • 6707
                or it can bee the ever famous rusted the F**K out wheel wells- theat are so popular here in Germany.
                • direction88
                  • Feb 2007
                  • 228
                  +1 for pics of drain locations.
