Lower Gas Mileage than Previous Times.
  • Jaygo333
    • Jan 2008
    • 334
    Just want to know, does anybody know what it means when you put in a full tank of gas and get 120 miles only.
    About 2 month ago, a full tank got me somewhere around 300 miles, haven't done anything except change a tire.
    The sensor tells me 120 miles and given that on half a tank I calculated I go 58 miles, that sounds about right.
    Ohh ya, since about 4 months ago, everytime I get gas, I put in one of these.
    Upper Cylinder Lube & Injector Cleaner
    Been adding it to my tank everytime I am at the gas getting gas.
    Right after getting gas, I add in a bottle.
    So, What can cause this sudden shift in Gas Mileage?
  • Moberg12
    • 209
    cause everywhere you get gas you get crappy E10, which uses more fuel to make than it replaces, causes FI problems, and burns faster. Ethanol FTL.
    Or you are running really rich, check your O2 sensor.
    • Edev
      • 3731
      i LOVE your sig. ive been thinking about getting an e36...325is. but everytime i drive my e30, it pulls me back in..literally :D
      and yeah..check your o2 sensor. mine is completely shitty. but im thinking its the original..327,xxx miles will do that to yours..hha.
      M Coupe
      • T Verdier
        • Aug 2007
        • 2636
        seafoam FTW!
        my friend who is a mechanic said everyone is coming to him telling him they are getting bad gas millage. he also said they changed the gas to cheapen it.
        • T Verdier
          • Aug 2007
          • 2636
          if your coolant temp sensor is bad your mpg goes way down sometimes. is it runing colder than usual?
          • Edev
            • 3731
            Originally posted by T Verdier
            seafoam FTW!
            so i should use seafoam first to see if it improves my mpgs? ive heard a few negative effects of using it?
            M Coupe
            • E30_fiend
              • Apr 2006
              • 7348
              The only negative effect I've heard from seafoam is on high mileage cars. If the intake system is really clogged, the seafoam could dislodge something large enough to impede flow somewhere. Other than that I have heard nothing but good things about seafoam. I do it to my car an my buddy's cars as well. They all love it. My buddy had his check engine light pop on but after driving for a while, it turned off.
              I'd say yet it, it will be a good 8 bucks spent.
              If you need help or instructions on adding the seafoam, shoot me a PM.
              Taylor
              • Jaygo333
                • Jan 2008
                • 334
                Ok, first what is F1?
                Secondly,. what's the E10 thing?
                New to cars don't hate plz.
                • Jaygo333
                  • Jan 2008
                  • 334
                  Ohh ya, and what does riding heavy mean?
                  • SpecM
                    • Oct 2005
                    • 4531
                    -That's "FI", fuel injection
                    -E10 is gas that is 10% ethyl alcohol
                    -"riding heavy?" running rich? just means too much gas is being used per unit of air
                    1989 cirrisblau-metallic 325i
