How Much Rust Is To Much
  • OrganicMechanic
    • Jan 2008
    • 1719
    I have Been working on my M3 now for a few months and have the drive line pretty much squared away. I get under it and look up and see the floor boards are shot through with severe rust. At what point do you decide that it is not going to be structurally sound and do what Vlad did and make a M3 Cabrio? I really like the idea of getting the M up so I can do HPDE (bmwcca won`t let carios particapate, only hard tops). I also love the idea of setting up a M3 cabrio. At what point do you give up the ghost and part out?
    join the E30 Cabrio owners gruppe
    click here for details
  • E30SPDFRK
    • 5716
    Never!
    Byron
    Leichtbau
    • RedHoodRidah
      • Feb 2006
      • 1096
      Originally posted by E30SPDFRK
      Never!
      This is why you are my boyee!!!! Ugh ow
      92 Granite Silver Vert
      M60B40 5spd
      • TDE30
        • 7042
        Personally, any rust that I can't Dremel or POR away is too much. For you though, if there is rust under the carpet (e.g. in the floor boards, as with your car,) I'd say you're probably in for some fairly radical reconstruction.
        - Trey
        E90 325i/6 (ZSP, ZPP, ZCW)
        E36 325i sedan
        E30 325i sedan
        Volvo 945T
        • BenM
          • 2184
          This much:
          Original thread from a long time ago :) - http://www.r3vlimited.com/board/showthread.php?t=88039
          Originally posted by BillBrasky
          E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
          1991 318i Alpine II - S50/5-lug swapped - track car
          1989 325i Cirrusblau - Daily
          1970 2500 - Malaga over Grey Cloth
          2012 F350 6.7PSD
          • uofom3
            • Jan 2004
            • 5392
            it really also depends on your abilities and budget. What might seem like an insurmountable task in rust repair to you could be negligable for someone else. Post some pics up for us to see. If it's a clean titled e30 m3, i would say save it unless the rust bug has bitten it so bad it is truly beyond repair. Because you're posting this, I would assume the car is either still salvageable or you're trying to be positive about it and don't want ot have to scrap the project :).
            PNW Crew
            90 m3
            06 m5
            • uofom3
              • Jan 2004
              • 5392
              Originally posted by BenM
              This much:
              that is for sure an example of too much.
              PNW Crew
              90 m3
              06 m5
              • archemedes
                • 125
                look at the muscle cars out there, what was not worth even trying to get parts from is being restored, cars with a following will start to disappear, and worse and worse examples will be fixed
                • OrganicMechanic
                  • Jan 2008
                  • 1719
                  I am going to take pics of the areas that have me most concerened. I may wind up haing a buddy go with me to the salvage yard and take a portable torch to cut a floor pan out. You`ll see what I am dealing with tomorrow.
                  • Ray McCooney
                    • Jun 2006
                    • 1088
                    I would post a technical reply, however, I'm told Californians are exempt from understanding the concept of "rust". Good luck.
                    • OrganicMechanic
                      • Jan 2008
                      • 1719
                      I have heard the same thing about Arizonaians, whom would be next in line to be the "new Califorinia".
                      see you all in Arizona Bay...
                      • Madhatter
                        • Oct 2004
                        • 966
                        as long as it doesnt get into the pillars, its only pressed sheet metal you are dealing with, so it doesnt really have any structural nature to it. So id remove the entire floor pan if it needed, its sills and the pillars that give me second thoughts.
                        Just a little project im working on
                        - http://www.lse30.com -
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          hey! as one of very few actual AZ natives...i really resent that!
                          i shall never surrender my state to californication!
                          as long as we have sherrif joe we are all good!
                          back on topic, if you are trying to keep it as original as possible, you could remove the sheet metal that is shared with a regular E-30 and replace the bad stuff in the M-3, you should be able to swap inner rockers and floors if i remember right. rockers can be tricky if you have never done them before, because the car can "close up" on you if not supported properly while the rocker is removed.
