Floor Pan Breaking in the trunk?
  • BMWLA
    • Jul 2008
    • 407
    I have heard that the floor pan in the trunk can break with big HP and solid diff mounts. I have some poping going on from the back end when I launch hard :shock:.
    Has any one had any breakage back there?
  • Rigmaster
    • 3464
    more of an E36/E46 problem.
    I'm sure it's possible in an E30, especially with an M5X/S5X swap- but it's not exactly a common problem. Shouldn't be too hard to fix/reinforce unless you let it go too long before you try to fix it.
    • FredK
      • 14762
      I think Stu had a problem in his S50US swapped car, after tens of thousands of miles. He welded and reinforced the area. I don't think he was running a solid diff mount, though.
      • DCColegrove
        • 2748
        The rear diff mounting point at the body is kind of like a paint can lid...
        Breakage isn't such a problem yet... (that I've seen)
        However the flex certainly isn't a good thing...
        Mason and I are actually working on addressing the issue right now with a modified rear brace "system" that will also reinforce the trunk floor.
        We'll probably have it out in several months...
