i found a whole write up on installing an automatic door locks unit a year ago but I cant seem to find it. Anybody have a write up to do it? Thanks
auto door locks
Man I just did this but I am way to busy/lazy to do a write up but I can give you cliff notes.
Peel back your driver side trunk liner and look for grn/blk(lock) and grn/prp(unlock) wires.
Now you want to splice these to the input side of the relay which is 86 I believe (1 relay for each) then run 87 as a ground you can even splice the two grounds together and only ground one wire. You need power to the relays (I used my power antenna wire) and use the signal from your alarm box to ground your relay. Anything past that pm me or
Oh someone fix any error they see here I just went off the top of my head.
