quick E28 question!!!
  • bimmer_E30
    • 5001
    ok me and my dad are about to close a deal on a 1995 740i E38. it has 200,000+ miles. but the car still runs good. i was just wondering if the E38s have the Engine block problem. :(
    for the record the guy said he will take 6000 canadain. p.s the car is not for me so don't flame LOL.
    Originally posted by e30e
  • Car Addict
    • Mar 2007
    • 1100
    that would be an e34 not e38
    the e38 was the 7 from 1994 to 2001
    unless you meant 740i
    • hugh jass
      • 2220
      you have to check with bmw to see if the block was replaced. either way, i wouldn't buy a bmw v8 with 200k on it.
      ______________________
      ex-Chief Operating Officer
      Blunt Tech Industries
      West Coast and Pacific Rim
      • TDE30
        • 7042
        The thread title says "E28" and you mention "E38," so if it is a 1995 540i I'll assume we're talking about an E34. Assuming you meant E34, I also assume you are referring to the Nikasil/Alusil debate. I'd say if the car has 200k on it, you are well past the normal point of expiration for most Nikasil motors. As long as it seems to run alright, it shouldn't be a concern. Make sure there is proper records/documentation, and make sure some of cooling components have been replaced or you'll be the one replacing them.
        Everyone is a skeptic when it comes to high-mileage M60's, but the truth is, if it has been properly maintained and has records proving that then it is just like any other motor. Radiator, coolant lines, water pump are all places I would observe carefully though.
        - Trey
        E90 325i/6 (ZSP, ZPP, ZCW)
        E36 325i sedan
        E30 325i sedan
        Volvo 945T
        • bimmer_E30
          • 5001
          how do i check??? also its a 740 SOOOORy
          • hugh jass
            • 2220
            Originally posted by TDE30
            The thread title says "E28" and you mention "E38," so assuming it is a 1995 540i I'll assume we're talking about an E34. Assuming you meant E34, I also assume you are referring to the Nikasil/Alusil debate. I'd say if the car has 200k on it, you are probably past the normal point of expiration for most Nikasil motors. As long as it seems to run alright, it shouldn't be a concern. Make sure there is proper records/documentation, and make sure some of cooling components have been replaced or you'll be the one replacing them.
            its the rest of the car i wouldn't want to own. a 200k e38 sounds like a major money pit unless it has been religiously maintained.
            • hugh jass
              • 2220
              i think any bmw dealer can tell you.
              • TDE30
                • 7042
                Meh, fuck, I thought he meant E34. Well, I'm sure E38's eat up suspension components, and they are probably littered with electronics, but I'd still go for one if the price was fair. They're very solid cars.
                - Trey
                E36 325i sedan
                E30 325i sedan
                Volvo 945T
                • bimmer_E30
                  • 5001
                  yah its a 740i E38 with 333,000kms . the guy is a bmw whore . he has like 4 bmws lol
                  the Link http://edmonton.kijiji.ca/c-cars-veh...QAdIdZ81331205
                  • TDE30
                    • 7042
                    Not bad, I would look it over very well though. Make sure the HVAC/audio controls aren't depixelating, that's usually pretty costly to replace those components. Check under the car, especially in the suspension/bushing area. They seem like great, solid cars, but they can just as easily be deep money pits.
                    - Trey
                    E36 325i sedan
                    E30 325i sedan
                    Volvo 945T
                    • bimmer_E30
                      • 5001
                      my dad is gonna be driving this so it should be good for him. also how about the engine???
                      • TDE30
                        • 7042
                        99% sure it has the M60, not the M62. If this is the case, refer to post #4. The same bit regarding cooling components applies with the E38.
                        - Trey
                        E36 325i sedan
                        E30 325i sedan
                        Volvo 945T
                        • euroshark
                          • Apr 2006
                          • 3491
                          The Nikasil problem was pretty much non-existent by 1994 / 1995 so there shouldn't be anything to worry about.
                          • bimmer_E30
                            • 5001
                            yah the car runs very good .pulls very hard and such. i guess its a deal. thanks guys!
                            • Dave McLaren
                              • Jul 2006
                              • 593
                              There was a transition during the '95 model year affecting E38s as well, from the nikasil to alusil block. That was also the year the E34 540, also with the M60 motor, transitioned to alusil, first with the automatics and later with the manual trans cars.
                              Chances are that if you have an early model, the block has been changed.
                              Dave
                              Present BMWs: E30 325iC, E39 540 Sport 6-speed, E60 M5 SMG
                              E30 Cabrio Turbo Project
