chatty valves
    chatty valves
    My valve lifters are pretty chatty. The PO said he had them serviced so I am not sure I need to adjust them. Is there any additive I can add to the oil to quiet them down? Suggestions?
    Thanks
    rmousir
    '87is work beater
    the RED BARON!
    RUNNING GREAT!
    After a $10.99 Intake Manifold Gasket.
    Maybe you should just check the lash anyay... what weight oil are you useing?
    1989 cirrisblau-metallic 325i
      10W30 and about 255000 miles. I should probably check the lash. never did that before. Any good how to articles on how to do that?
      rmousir
      '87is work beater
      the RED BARON!
      RUNNING GREAT!
        With the mileage i think you should use a higher grade of oil. Maybe a 15/40.
          agreed, maybe even 20w-50 if its not too cold where you live.
            I would recommend a good ZDDP additive for all of us old Bimmer drivers. It's not going to make your valves any quieter, but it will protect all metal on metal contact areas. M20s are naturally kinda clattery in the head so adjust your valves correctly and forget about it.
              What he said. Adjusted mine hot and cold. Same chatter.
              Every day I wake up we drink a lot of coffee and watch the CNN
              Every day I wake up to a bowl of clover honey and let the locusts fly in.
              Lobsterbacks attack the town again
              Wrap all my things in aluminum
              Beams of darkness streak across the sky
              Pink rays from the ancient satellite
              Every time I look out my window same three dogs looking back at me.
              Every time I open my windows cranes fly in to terrorize me.
                OK.. I will look at a higher grade of oil. I will also look into adjusting my valves. I am sure I have seen that in my BMW book.
                rmousir
                '87is work beater
                the RED BARON!
                RUNNING GREAT!
                  When i changed my oil last week, i decided to try the Lucas oil stabilizer. It really did help quiet the valvetrain a decent amount. I was impressed. Some people claim mpg increases with it, but i have yet to go through a full tank. I'm using 10w-40 btw. Give it a shot.
                    Any reccomendations on brands?
                      "ZDDPlus" is pretty darn good I think.
                        +1 on what everyone else said, but read about oil additives through a Google search. It's not recommended.
                          Well we can test the oil additives do damage myth or truth on my car. I used Lucas Oil stabilizer this last oil change. I have the Blackstone labs report for the oil I ran before this last oil change. I just need to get to the next oil change so I can send in another sample with the additive in it.
                          John
                            ZDDP used to be in all oils (or most of them) until recently, so I don't consider it an additive. Think of it as a replacement for something that should be in the oil in the first place.
                              Use an oil labled as "high mileage", they usually contain ZDDP/zinc
                              Castrol GTX 10w-40 HM or Rotella 15w-40 are my picks
