Opinions on front susp. rework
  • bev
    • Oct 2007
    • 172
    Due to a broken subframe swaybar bushing mount, I thought I'd redo my front end. Looking for fairly sporty, but not full on race. As far as I know, the car has never been touched since new, except struts.
    Replace List:
    1. Front subframe
    2. Swaybar mount bushings (20mm stock) Pelican @ $6 x 2 = $12
    3. Swaybar endlinks (stock) Pelican @ $40 x 2 = $80
    4. Front control arm bushings (stock, no offset) Pelican @ $27
    5. Urethane Engine mounts (IE) Bimmerworld @ $90
    6. Outer tie rod ends (stock) Pelican @ $36 x 2 = $72
    7. Control Arms (stock) Bimmerworld @ $180/set
    total: $501
    Any suggestions on changing/adding anything? Down the road I plan on adding H&R Races and Bilstein sports.
    thanks.
  • z31maniac
    • 17566
    I'd do M3 control arm bushings and the complete tie rod assemblies. And I'd buy AKG motor mounts instead of IE.
    I would also buy the Turner Motorsports front subframe reinforcement kit and beef up the subframe since you will be changing it.
    www.gutenparts.com
    • StereoInstaller1
      GAS
      • 22679
      I think any discussion of suspension parts should start with what your expectations are.
      Closing SOON!
      Thanks for 10 years of fun!
      • Van Westervelt
        • 9365
        You are putting in stock Control Arm bushings, yet you are putting in Poly engine mounts? Makes no sense to me son.
        Put in stock engine mounts, and use offset, e30 m3 CA bushings for improved castor.
        • StereoInstaller1
          GAS
          • 22679
          Urethane CABS for improved braking, too.
          Closing SOON!
          • T Verdier
            • Aug 2007
            • 2636
            m3 solid offset bushings for street use is the best i heard.
            also bavauto has Febi control arms for $160 a set free shiping and febi is owned by bilstien so the quality is probably good.
            • clavinZERO
              Hella sick E30
              • Mar 2004
              • 2027
              TJ, I have had the poly Control Arm Bushings on 2 cars personally. Only way to go. More durable and cheap still. Also what Stereointaller says seems valid... less flex = more direct relationship between tire rubber and braking effect. Amirite?
              "BMW Style 32 Poster-Child"
              HTTP://WWW.CLAVINZERO.COM/e30-5-lug
              **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
              • bev
                • Oct 2007
                • 172
                So urethane CABs (offset? I've read lower speed cornering suffers with offset), AKG motormounts (which?), and turner front subframe reinforcement?
                thanks for the help so far.
                edit-found 75D offset and nonoffset CABs from AKG, seems like whats recommended.
                • StereoInstaller1
                  GAS
                  • 22679
                  The urethane CABs are a very easy install, too.
                  Why urethane motor mounts?
                  Closing SOON!
                    • 37829
                    If it were my car, I'd go with OEM offsets, not delrin or poly.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • bev
                      • Oct 2007
                      • 172
                      No real reason, I suppose.
                      edit-so even though I am looking for a bit sportier handling, I should go full OEM?
                      • SpecM
                        • Oct 2005
                        • 4531
                        yes... I would say so
                        1989 cirrisblau-metallic 325i
                        • clavinZERO
                          Hella sick E30
                          • Mar 2004
                          • 2027
                          Poly will be stiffer and sportier, but new OEM stuff will be better than the beat-up old stuff you have in now anyways.
                          I say if you go polyurethane on anything, get the soft or "street" version of it since you are not driving a race car. It's like "stock +1" but not fuh-raze (aka full race in case you are a newb).
                          • StereoInstaller1
                            GAS
                            • 22679
                            The wifes car is 100% stock except urethane CABs. No significant difference in NVH, but a HUGE difference in braking and general "feel".
                            Best $50 you will ever spend in suspension.
                            Closing SOON!
                              • 37829
                              Even with my E36 M3 front end, I am running OEM E30 M3 CAB's.
                              Grover Beach, CA
                              www.BimmerHeads.com
