shifter bushings
  • rmousir
    • Nov 2007
    • 147
    shifter bushings
    Hi all,
    How hard is it to put in new bushings into my shifter. the ones I have in there are shot and I see the kit for new parts is out there. I wonder how hard it is to do. Anyone have a 'how to' on it?
    Thanks
    Richard.
    rmousir
    '87is work beater
    the RED BARON!
    RUNNING GREAT!
    After a $10.99 Intake Manifold Gasket.
  • redhatpat
    • Aug 2005
    • 656
    You need to drop the exhaust, heat shields, then the driveshaft. Then you can access the shifter. Nothing terribly hard, but a pain to take so much apart just to get to the shifter. That's my project this weekend.
    • Jean
      • 18228
      Also keep in mind there are two types of shifters used in e30s when you order your parts.
      • kid325e
        • Sep 2007
        • 6421
        rmousir, where can i find this shifter bushing "kit"? My shifter has some slop in it as well.
        clutchCTRL!
        Move with a purpose.
        - 1991 325iX 4dr/5spd
        - 2000 323i AT
        2016 Mazda CX3 Sport AWD
        • gearheadE30
          • Jun 2007
          • 3734
          I got a kit of sorts from BMAparts for $75 iirc. I installed a z4 2.5 shifter at the same time. BTW I did not drop the exhaust or the driveshaft. On M42 cars at least, it is easy enough to just pull the heatshield.
          Project M42 Turbo
          • rmousir
            • Nov 2007
            • 147
            kid325e
            you can get the kit from http://www.pelicanparts.com/BMW/index.htm
            redhatpat
            let me know how it goes and how long it took. I am in no hurry because I did not order the kit yet but I think I am going to. I need to keep this car for a while but if I do sell it that will be a hard one to explain.
            thx.
            rmousir
            '87is work beater
            the RED BARON!
            RUNNING GREAT!
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              if you're gonna change the shift carrier bushing, you might want to unbolt the tranny brace so you have enough room to remove the bitch clip, if you're changing just the shifter you dont need to drop exhaust, it's not even in the way.
