I have billy sports on H&R Race springs just installed and there is play at the top of the shock between the camber plate and the shock nut when I push on the car towards the floor. Basically I was thinking... Is the nut not down enough, or do I need a shorter bilstein shock (do they even make another size?). Please help. I hate the clunking of this damn car while driving. Thats why I am not driving it.
Suspension Technical question.
Sounds like you dont have the shock centered in the mount. If so its a PITA while on the car, usually requires removal and reassembly.sigpic -
the shock isnt lined up with the bearing and perch properly. You might luck out and get it lined back up, but thats a long shot in the dark. remove, look at how snug it all fits without the spring, then reassemble.sigpicComment
You do have plates made for bilsteins, right? The tops of konis differ slightly from the bilsteins.Comment
