Clunky vibration
  • 88E30325ITN
    • Jul 2008
    • 47
    Clunky vibration
    So I just replaced both front control arms because one of them was worn out, it was metal on metal for a few days. I still have a clunky sound and a vibration that matches it in the steering wheel upon braking or hitting a pot hole. I am thinking it is the struts, but I am not sure. I guess it could be wheel bearings but those were replaced last spring. It is only on the right side which is the same side the control arm went bad on. Any ideas? It sounds almost exactly the same as when the control arms was bad just not as drastic.
    I feel like a fish out of water, most times.
  • iwillhunt
    • Oct 2007
    • 385
    Check to make sure the sway bar mounts aren't broken or damaged. I had the same problem, and it was due to a broken bracket where the sway bar mounts to the sub frame. It could very well be strut related though.
    • 88E30325ITN
      • Jul 2008
      • 47
      Thank you. I am doing on oil change by Thursday I will take a look. While I am under there. Anyone else?
      • AndrewBird
        The Mad Scientist
        • 11898
        What all did you replace when you replaced the control arms? Did you do rear control arm bushings as well? Could be upper strut mounts.
        • Reign
          • Nov 2008
          • 125
          I had the same problem with my Mercedes and it was the wheel bearings.
          As you can see with all of the posts, it can be anything that is attached to the wheel. Just make sure you take a look through everything thoroughly. It can be dangerous.
          '91 318iS
          Koko's Garage - BMW and Mercedes Specialists
          651 Mount Auburn St, Cambridge, MA, 02138
          Selling This Car:
          http://r3vlimited.com/board/showthread.php?t=132392
          • 88E30325ITN
            • Jul 2008
            • 47
            I am thinking it might be a warped rotor. What does a set of drilled and dimpled rotors cost?
            • ethree
              • Aug 2007
              • 1213
              Unless you really like the look of drilled rotors I think high quality blanks and fresh pads are the way to go. I just installed my brembo blanks ~$40 each from bma and hawk hps pads with fresh fluid and the difference is night and day.
              • iwillhunt
                • Oct 2007
                • 385
                I have this exact setup, and like it a lot for DD/some track use.
