Can CV joints make a screeching noise?
  • gearheadE30
    • Jun 2007
    • 3734
    Starts suddenly at about 25 MPH, cuts out when the car comes to a stop. Doesn't always show up, and isn't very regular. Sumetimes goes away after driving a bit. The car drives fine, but the noise is rather obnoxious. It varies only with wheel speed.
    Normally, CV joints click, but I just did the wheel bearings, so that can't be it unless I damaged them on install. Joints have 210k miles on them.
    If I inject some CV joint grease into the boot, will that cause a problem? I don't know if CV grease is generally compatible with other CV grease, or what effect having 2 types of grease will have.
    Any ideas or opinions on the matter? I would prefer to not have to buy new axles.
    Project M42 Turbo
  • SpecM
    • Oct 2005
    • 4531
    I'm not so sure they will make a "screeching" noise
    did you check for play/binding? Also, check your calipers, maybe one is hung-up.
    1989 cirrisblau-metallic 325i
    • gearheadE30
      • Jun 2007
      • 3734
      I thought about the calipers, but the brakes work fine and brake use does not seem to affect the noise. It may do something under heavy pressure, but the car stops so quickly that the noise dies off before I can determine an effect.
      Project M42 Turbo
      • gearheadE30
        • Jun 2007
        • 3734
        Bump, still havn't figured it out. Brakes look fine, but I'll have to pull them off to be sure.
        Project M42 Turbo
        • BMWLA
          • Jul 2008
          • 407
          look at the brake backing plate may be touching the rotor.
