POR-15. Sand and Buffable???
  • BrewCity11
    • Mar 2008
    • 2335
    Searching for an alternative to powdercoating a metal bumper. Has anyone wetsanded and buffed out POR-15 to a decent finish???
    turk@gutenparts.com
  • der affe
    Technical
    • Dec 2005
    • 8452
    it maybe possible. i have polished the stuff that wurth sells (basically the same thing) it holds a shine well.........buy it doesn't stand up to rock chips very well as that was not its original purpose.
    i also sprayed it on instead of brushing it, you just need to reduce it a little then spray it from a gun. it will lay pretty smooth, and the orange peel will flatten as it dries. the drying times are longer since you thinned it out though.
    • BrewCity11
      • Mar 2008
      • 2335
      Well, lemme ask another question, then. Do i have to powdercoat euro bumpers, or should i just paint them.
      I'd rather save money by doing it myself, as long as there is a painting method that will hold its own.
      turk@gutenparts.com
      • der affe
        Technical
        • Dec 2005
        • 8452
        as long as there is good adhesion, the powder coat should last longer then paint and be more chip resistant
        • Jand3rson
          • 37587
          Have you stripped the chrome off yet? I would have them powdercoated. The powdercoating shop will also be able to strip them chrome off of them before they coat them, making for perfect adhesion. It's going to cost more, but it's going to be your best bet for durability.
          • OrganicMechanic
            • Jan 2008
            • 1719
            there is a how-to out in google-land that gives a process that uses muriatic acid, big plastic tub, cooper leads and low amp battery charger to strip chrome.
            join the E30 Cabrio owners gruppe
            click here for details
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              POR 15 is apparently UV sensitive, it can get a chalky whiteish color on it if left uncovered by a top coat. I haven't used much myself, though I do have some. I have no first hand experience, but I've heard of it.
              • tim88325is
                • Jul 2008
                • 201
                Isn't POR 15 really toxic? Be wary of breathing the dust...
                Although maybe not more toxic than "regular" auto paint or primer?
                • BrewCity11
                  • Mar 2008
                  • 2335
                  I was planning on taking it to a local sandblast shop where you rent a booth for however long you need it. My buddy took his wheels there once and said it worked magic on the layers of powdercoat on the wheels.
                  This should work,no? Is chrome too strong to be sandblasted off?
                  The car is my budget winter beater and i shouldn't have even gotten euros for it but i couldn't pass up the deal.
                  Maybe i'll just leave it as is and have them p/c'd in the spring. We'll see.
                  turk@gutenparts.com
                  • OrganicMechanic
                    • Jan 2008
                    • 1719
                    chome is transfered to the bumper via electrolysis. I really don`t know if media blasting will remove the chrome.
                    • BrewCity11
                      • Mar 2008
                      • 2335
                      True, but technically, chrome is just a "coating" as well, and thought some type of media would be able to get it off. I've sandblasted OEM BMW tools that are chrome plated, but only the ones that already had peeling chrome, came off easily.
                      The bumper i'm getting is pretty rusted on the back side, so I may be able to blast it all off.
                      If not, i'll just sand and paint for now.
                      Thanks for the comments
                      turk@gutenparts.com
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        blasting and priming the back would be fine to prevent rust, but sandblasting also tends to leave a more wavy surface if you paint or re-chrome it. Media blasing isn't as bad, but the acid/current ida seems the best bet if you want a smooth finish.
                        Either way, I would powdercoat the bumpers so they don't chip or fade as badly.
                        Project M42 Turbo
                        • eurohick.
                          • Nov 2008
                          • 126
                          if you bring it to a powdercoater, they are gonna have the bumpers chemically stripped, its the only way to remove all chrome from the surface. It can get expensive.
                          POR-15 isnt made to be used as a topcoat, as stated it is UV sensitive, itll look like hell in no time. It lays down beautifully if sprayed out of a gun however.
                          • FredK
                            • 14759
                            POR-15 is a moisture curing polyurethane, so you need to be well-protected during spraying. Once it is cured it should be as inert as regular auto paint / primer, but curing will take longer than two component systems.
                            They do have UV resistant topcoat products.
                            • cactusjacks1
                              • Sep 2004
                              • 1216
                              DO NOT sand blast chrome off euro bumpers - it is thin metal & they will warp from the heat.
                              Taking chrome off is very easy - it uses the identical process as chroming, but in reverse. It's cheap, no materials involved, minimal labor, just a bath in three different vats. So, find a chrome shop & ask him to strip the bumpers. Most of these shops have the equipment to straighten the bumpers if they need a little work.
                              Then you prep them with a rattle can of self etching primer (SEM 39683), lightly finish sand & apply rattle can SEM Trim Black (#39143 - it is a satin finish) - reapply rubber trim & install bumpers.
                              A simple DYI - $30 strip, $30 paint & materials.
                              [I
