BBS Motorsports Racing Wheels
  • diegom6
    • 4447
    So, wich of the following models do you like more for a e30?
    I'm on hard time to decide if liek more the e87 or e26, e28 are nice but 18" and up, doesn't fit so well in a e30 IMO due the size.
    BBS E30: 13˝-centre-section with 16 bolts to fix
    the rims; usualy available for 4-bolt-mounting;
    also available: 3- or 5-bolt- or centre-bolt-mounting.
    Available wheel sizes: 13˝-flatbase-wheel or 14˝-
    or 15˝-drop-centre-wheel.
    Only by Käfer-Motorsport: BBS racing wheels are
    now available again as 14˝-drop-center-wheel
    Note: It’s not possible to mount or remount the tyre on a flatbase wheel as usual! The wheel has to be disassembled and remounted into the tyre! Otherwise damage is caused!
    All outside rims come polished and prepared for filler installation. 13˝-inside-rims come polished too, 14˝- and 15˝-inside-rims do not. Inside and outside rims are produced with hump.
    BBS E50: 15˝-centre-section with 20 bolts to fix
    the rims; usualy available for 5-bolt-mounting;
    also available: 4-bolt- or centre-bolt-mounting.
    E50-center-size also available as the
    new design E26.
    Available wheel sizes: 15˝-flatbase wheel or
    16˝- or 17˝-drop-centre-wheel.
    All outside rims come polished and prepared for filler installation. 15˝-inside-rims come polished too, 16˝- and 17˝-inside-rims do not. Inside and outside rims are produced with hump.
    BBS E26: 15˝-centre-section with 20 bolts to fix
    the rims; available for 4-bolt-, 5-bolt- or centre-
    bolt-mounting
    Centre section can be made for mounting behind
    or ahead of the rims.
    Available wheel sizes: 15˝-flatbase wheel or 16˝-
    Note: It’s not possible to mount or remount the tyre on a flatbase wheel as usual! The wheel has to be taken apart and remounted into the tyre! Otherwise damage is caused!
    BBS E87: The new centre-section with 20 bolts to fix the rims; available for 4-bolt-, 5-bolt- or centrelock-mounting.
    The E87 wheel centre is milled out of a forged aluminium blank. By precise milling the wheel centre can be made even lighter than the casted magnesium E26. The difference in weight of the centre is about 200 g.
    Available wheel sizes: 16˝- or 17˝- drop-centre-wheel.
    Centre section can be made for mounting behind or ahead of the rims.
    All outside rims come polished and prepared for filler installation, inside-rims do not. Inside and outside rims are produced with hump.
    BBS E28: Centre-section with 24 bolts to fix
    bolt-mounting.
    Available wheel sizes: 18˝-, 19˝-, 20˝- or 21˝-
    drop-centre-wheel.
    Center section can be made for mounting behind
    BBS E88: The new centre-section with 24 bolts to fix the rims; available for 4-bolt-, 5-bolt- or centrelock-mounting.
    The E88 wheel centre is milled out of a forged aluminium blank. By precise milling the wheel centre can be made even lighter than the casted magnesium E28. The difference in weight of the centre is about 200 g.
    Available wheel sizes: 18˝-, 19˝-, 20˝- or 21˝- drop-centre-wheel.
    I
    BBS E68: 11˝-centre-section with 12 bolts to fix
    the rims; available for 4-bolt- or centre-bolt-
    mounting;
    Available wheel size: 13˝-drop-centre-wheel.
    Centre section is mounted behind the rims.
    Outside rims come polished and prepared for filler installation, inside-rims do not. Inside and outside rims are produced with hump.
    24
    E30
    25.00%
    6
    E50
    12.50%
    3
    E26
    16.67%
    4
    E87
    8.33%
    2
    E28
    12.50%
    3
    E88
    20.83%
    5
    E68
    4.17%
    1
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • kronus
    • Apr 2008
    • 13032
    E87
    cars beep boop
    • hugh jass
      • 2220
      does your family own peru or something? those are some spendy wheels!
      ______________________
      ex-Chief Operating Officer
      Blunt Tech Industries
      West Coast and Pacific Rim
      • SamE30e
        • Sep 2007
        • 4319
        BBS E28's <3
        1985 325e 2.8 Turbo VEMS
        • Jand3rson
          • 37587
          Jesus, I just blew a load all over this thread. :shock:
          • E-Thirty
            • 1331
            Definitely the e50.
            Do you feel like something is trying to penetrate your butthole?
            • dannyyisntt
              • 3141
              Mis-voted meant to vote e26...
              • e34john
                • Apr 2006
                • 3599
                E26, Some of those later ones look nice, but not squared enough to be put on E30s.
                • cferb
                  • 1442
                  +1 e26
                  • E30Eric
                    • Sep 2007
                    • 156
                    E88 FTW...
                    E30: 1
                    Wallet: 0
                    1988SuperETA|Full I component swap|19lb injectors|Schrick 272|MSIIExtraBeta20071020|GM DIS Wasted Spark|LC-1
