The Good Question and My Answer.
  • DCColegrove
    • 2748
    I don't know when you came into this but the discussion has a lot of history...
    I'm probably at the end of my rope with it for many reasons... and have been extreamly short whith my detractors for a while now.
    However...
    I do not mind answering an honest question here (also sent you via PM)
    Originally posted by gstuning
    I´m so assuming you took the chassis and BENT it in a bench and derived all your construction parameters from there.
    i.e the bending stresses and how much angular movement there was with x amount of force to the shock towers and subframe and where thus able to find the the ideal bracing to stop the chassis from bending. Or did you just weld some stuff in a few times to make it stop bending?
    There is a difference between imperical "engineering" (fiddling) and engineering (good old math)
    I´m all for discussion , but only when people answer with discussion and not little remarks.
    I wasted a lot of typing on it though then the thread was locked…. I’ll start over.
    My job a long time ago was to dream up ways to test what engineering came up with… To shake out unforeseen failures diagnose the cause and help correct them… I’m not saying the math was wrong I’m saying that there is LUC (Law on unintended consequences) no matter how many times you run numbers something in real life will break...
    But… Yes you assumed correctly on both counts… both empirical (fiddling) and hard math engineering (math mostly already done for me).
    The original measured data was derived from a raw e30 on a 7 post (7 plane) Chassis shaker… At this same time the effectiveness of several braces were tested.
    I had the luck and luxury to borrow this machine because the owner is a friend who was exceptionally helpful in bringing me up to speed on modern telemetry and data collecting methods.
    My original intent was not to sell bars or anything else to anyone... We were just curios. But then I went on a mission after what we found...
    These braces are designed and have been tested to directly address chassis flex that was measured on that chassis shaker… And also tested for any unintended results of mitigating the flex we set out to mitigate.
    I have posted some of the actual data here on R3V somewhere… I’ll dig some of it up again if you can’t find it.
    These braces (front Strut, Lower X, Rear Brace system) are not “ideal” in the strict sense but as ideal as a bolt on assembly can be to mitigate undesirable chassis component compliance. They are an alternative to building a full on GT2 (or what have you) for the guy out there that doesn’t want to gut his car and weld in structural bracing.
  • z31maniac
    • 17566
    First.
    www.gutenparts.com
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      *White Noise*
      • atomic
        • Jun 2007
        • 5691
        oh Lord!
        3rd
        edit--- hopefully there will be some useful info to come from this....
        :up:
        • DCColegrove
          • 2748
          This would go a lot smoother without the "noise".
          This was posted by me a while ago on comparing front stress bars:
          Originally posted by DCColegrove
          mounted as intended the sparco bar was bitchin good at controlling flex of the strut towers in and away from each other. Not so good in controlling front to back (twisting) At the top end of knocking the shit out of the chassis on the shaker it allowed just over 22mm of this motion (total measured at the top of the struts)
          The bar (fabricated by John) we are using now only allowed 7mm same program same chassis (swapped/tested...swapped/tested 3 iterations in a row)
          • direction88
            • Feb 2007
            • 228
            This should be good...
            "Drifting an E30 is like pouring out a beer just to get a nickel for the can"
            • DCColegrove
              • 2748
              This is a useful contribution to this discussion?
              Or is you point to bait me into loosing my patience.
              • z31maniac
                • 17566
                No, into losing your patience.
                www.gutenparts.com
                • kishg
                  • Sep 2006
                  • 2624
                  ok, i'll bite DC. Can we see the original measured data? and what range is within normal operating parameters and what is beyond, like when on a track? that would determine if your braces and bars actually have a practical benefit or are overkill wouldn't it?
                  '12 F30 328i Sport Line
                  '91 SpecE30 #523
                  '00 Ford F-350 Dually Tow Vehicle
                  BMWCCA #360858 NASA #
                  128290
                  • rwh11385
                    lance_entities
                    • 18403
                    So was it a sparco bar... or a IE knockoff?
                    There are a lot of bent e30s out there...
                    I used sparco bars until I had an e30 on a 7 post chassis shaker and actually saw what was going on with them in real time (actually broke a Sparco knock off and the BMP bar).
                    After that I got togeather with John to really solve the problem.
                    Eh, doesn't really matter, you'll never redeem yourself no matter what to the BMW community and be as big of a joke as Budget Beater or Jordan Sarette.
                    • kishg
                      • Sep 2006
                      • 2624
                      i'm willing to cut him some slack and as for jordan, he might be a cocky, arrogant sob but he actually knows what he's talking about most of the time. i respect that.
                      '91 SpecE30 #523
                      128290
                      • DCColegrove
                        • 2748
                        The shaker is controlled by a computer that is loaded with data collected via telemetry from real race cars on real race tracks.
                        You can "run" the chassis using the same loads etc from that.
                        And we tested both the Sparco and the knock off bar... The knock off broke and so did the BMP bar under what would be extream but not uncommon loads.
                        • kishg
                          • Sep 2006
                          • 2624
                          ok. fair enough, and the sparco didn't break? did you measure the chassis flex at different points with and without bars and braces?
                          '91 SpecE30 #523
                          128290
                          • DCColegrove
                            • 2748
                            Yes if you look at my op you will see we started with the chassis originally as delivered from BMW.
                            EDIT Correction: The car did have new H&R Race springs and Bilstein sports installed on it.
                            Edit: It was suprizingly pliable... More so than I had originally thought.
                            • kishg
                              • Sep 2006
                              • 2624
                              Yes if you look at my op you will see we started with the chassis just originally as delivered from BMW.
                              yes, i read the OP. i was hoping for some actual data, numbers..
                              '91 SpecE30 #523
                              128290
