225 50 15's-will they fit........
  • 325YOY
    • 142
    on euroweaves with stock suspension without rubbing? I had them on my LS's without a problem but my tire guy says on the 7" ET24 euroweaves there will probably be some rubbing if I go with the 225 50's instead of 205 55's. 225 50's are quite a bit less expensive even though they are larger.
  • DCColegrove
    • 2748
    Yes they work fine right up to a 30mm drop...
    Tiny rub at full lock on the inner skin but that's it... If you have M3 offset CABs not even that.
    • RickSloan
      • 2401
      im runing 215/60/14's i think right now on a 6.5 inch wheel and honestly i hate it. I guess your side wall will be much shorter but its like riding on ballons and you can feel it...
      just my .02
      Need Illustration or Design work? www.robbiebyerly.com
      • DCColegrove
        • 2748
        225 50 15 on the "euroweaves" work fairly well for me.
        • Nic01101011
          • Jan 2008
          • 1549
          running 225/50/15 RS2s(very wide) on Euroweaves w/ a 60/50 drop, fenders rolled and everything fits but just barely. Stock is high enough that the suspension may never be compressed to the point where the tires would meet the fenders.
          • DCColegrove
            • 2748
            Just so you could see it
            These are 512 Falkins 225/ 50/ 15 @ 30mm drop.
            • rThor432
              • Feb 2007
              • 3907
              Yep they'll fit fine assuming you have the right offset wheels. Here's proof--
              225/50/15 RS2's--
