E30 dies in traffic..
  • killa325i
    • 427
    like it says above, motoring down the road and the motor just shut down. turns over just fine, but wont fire. didnt smell fuel under the hood after repeated attempts to start it, so my guess is fuel related. btw, it's a 1990 325i. any thoughts before it gets towed to the shop?
    Shoot, move, and communicate...
    ......Semper Fidelis.....
  • DCColegrove
    • 2748
    DME relay... whack it while it's running and see if it stalls or coughs.
    • dannyg
      • Mar 2007
      • 1553
      Take off the cap on the valve cover and have someone turn the key. See if the motor is actually turning, if it's not, your timing belt is broken. Ouch.
      1993 325ic Schwarz/Natur
      1991 318is Black/Black - Slicktop - Project s52
      1989 Alpine White/Black M3 S52
      1988 Henna/Pearl M3 <3
      • DCColegrove
        • 2748
        Yeah that too...
        did I miss understand that it's on going or did it just quit and that's it...
        • killa325i
          • 427
          Originally posted by DCColegrove
          Yeah that too...
          no it just quit, and now it wont fire.
          • dannyg
            • Mar 2007
            • 1553
            I'm guessing the turning that you are hearing is the starter. The engine won't turn over because the timing belt is broken...
            • Philo
              Ich esse kleine Kinder
              • 3334
              Wait. When did he say it is not turning over? It might be something more simple then jumping to the timing belt conclusion. Random guesses would be fuel pump, fuel pump relay, reference sensor. Unless i misread the post.
              -tim
              Originally posted by Jordan
              I like the stance
              • gearheadE30
                • Jun 2007
                • 3734
                I wouldn't jump to the timing belt just yet. He said it turns over fine. You would really notice if the timing belt was broken. Well, at least I'd hope you would.
                Project M42 Turbo
                • killa325i
                  • 427
                  this is what i'm thinking.
                  • Philo
                    • 3334
                    Do some simple bentley tests.
                    To test fuel pump: #1 listen for it to come on. It is located under the right rear drives seat. #2 pull the line at the rail, crank to see if it pumps fuel.
                    To test FP relay: pull box, check for power at relay(red wire)/pin30. If that fails check the fusable link in the right rear of the trunk. Check pin86 + pin85 with a voltmeter/multimeter while turning over the car. You should get a change in reading. Finally jump pin30 to pin87 with a fused wire. If the pump runs then it's either a faulty relay or bad reference sensor.
                    To test reference sensor: pull plug located @ 4:30 (from front of car) next to the diagnostic center, and test the black and yellow wire with a multimeter. You should get 540 +- 54 i think.
                    The reference sensor is gonna be my guess. Good luck with fix. Keep us posted.
                    -tim
                    I like the stance
                    • SamE30e
                      • Sep 2007
                      • 4319
                      Easy there jump to conclusions.
                      Check for the basics. Fuel and spark then go from there.
                      1985 325e 2.8 Turbo VEMS
                      • Philo
                        • 3334
                        Paging killa 3 2 5. . . .
                        -tim
                        I like the stance
