Brake line question
    Brake line question
    With the upcoming 24v I'm planning on ditching the ABS pump since the ABS doesn't work anyway.
    Can I just buy the brake lines from a non-ABS e30 (or bend our own) and hook them up where they are now? IE, just straight from the master cylinder to brakes vs being routed through the ABS pump?
    Would this cause any strange bias issues or anything?
    www.gutenparts.com
    I used brake line from O'Riley's with a good tube bender and ISO bubble flare kit, To remake the lines under the M/C that go to the ABS pump. I could rent you the bubble flare kit for shipping if you cant source the flare kit locally.
    I am not sure about the Bias, You could just get a Brake Bias adjuster?
