NEW cold air intake kit ideas
  • kamotors
    • Nov 2007
    • 7102
    Well after my old filter got discontinued I kept on selling the kit with a similar filter but not the one that has the clamp on end, so I decided its time to make a new setup.
    I basically have an infinite supply of these filters because they are being custom made. I'm here for some suggestions not people saying how stupid cold air intakes are, if I can get cooler air temps than the OEM air box, snorkel,headlight shield setup I'm happy. I was really happy with my last kit, its was very unrestrictive,easy to maintain and really got cooler I.A.T's. this kit will be for basically all e30's because the filter is already shielded.
    So please tell me what you would like to see included in this kit.
    I can either do it the same way I have been with the hose that leads to the grill or I can have a nice short hose that leads to the triangle betwen each headlight, the triangle method would require the owner to dremel the slots so air can flow threw it.
    7speedshop.com
  • BeirBrennerE30
    • 2740
    no... impending hp loss and engine damage
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • kamotors
      • Nov 2007
      • 7102
      please tell me why? the kit will basically the same as a BMA CDA kit?
      7speedshop.com
      • BeirBrennerE30
        • 2740
        The intake of the m20 isnt the restriction. and all those bends you are adding pre filter act to reduce flow into the filter itself. Why do you think you need to route the airfilter to the front of the car like that?
        also most aftermarket filters left in a lot of debris and grit into your engine
        e30sport.net
        • e30s52
          • Oct 2007
          • 5235
          Those are alot of bends in the pipping.
          www.gutenparts.com
          • kamotors
            • Nov 2007
            • 7102
            thats why I like my old filter setup so much, because the filter wasn't restricted to breath threw the bends that was just its supply of cold air, it could breath threw the sides and it was extremely good at filtering, in a test it filtered way more than any K&N filter. thats why any suggestions are welcome, I could just go straight to the grill but then their is modifying of the grill which most people don't want to do.
            7speedshop.com
            • E30_Pare
              • 7801
              Routing from a brake duct? Or possibly a fog slot.
              DREWLIENTE
              1$ PShops PM me
              • e30s52
                • Oct 2007
                • 5235
                You want to see hp inprovements I think thats what you are going have to do.
                www.gutenparts.com
                • kamotors
                  • Nov 2007
                  • 7102
                  brake vent would be easy but unless people are willing to cut into their car, that setup would also have bends in it.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    this would breath threw the OEM headlight shield but then it defeats the purpose of the kit. we want colder air not as cold air as the OEM setup.
                    7speedshop.com
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      Looks good, the 2nd design is definitely superior. BeirBrenner, the intake velocity will not be high enough to be affected by that small little bend. Maybe if the air were moving at 200cfs, but at the relatively small velocities and volumes produced by our cars, it will have virtually zero effect.
                      • george graves
                        • 19996
                        Hey - what ever else is going to be said in this thread - I'll tell you this, I like your drawings. It really shows you put more than just a after though into this. Hats off to you. It's nice to see someone working towards backing up their claims.
                        Originally posted by Matt-B
                        • kamotors
                          • Nov 2007
                          • 7102
                          and remember guys I'm not going for a RAM air kit just cooler I.A.Ts.
                          7speedshop.com
                          • E30_Pare
                            • 7801
                            anyway to create a vacuum effect without the vacuum...
                            ram air would be cool.
                            DREWLIENTE
                            1$ PShops PM me
                            • kamotors
                              • Nov 2007
                              • 7102
                              thanks
                              7speedshop.com
