Planning a long trip...
  • brantleyr
    • Apr 2008
    • 375
    Planning a 700 mile trip in e30, things that need replaced?
  • mrsleeve
    • Mar 2005
    • 16386
    get a new car !!!!!!!!!!!!!!!
    Originally posted by Fusion
    William Pitt-
    • Devil Inc
      • Jan 2008
      • 802
      nothing if you've kept on top of maintenance items.
      • e34john
        • Apr 2006
        • 3599
        Yea, shouldn't be a problem if the car is maintained. Make sure your cooling system is in shape and the check the air in the spare tire.
        • brantleyr
          • Apr 2008
          • 375
          no matter what question you ask theres always one person to say get a new car...
          • brantleyr
            • Apr 2008
            • 375
            car has driven strong for two years, replaced suspension parts, guibo, csb, driveshaft, put in 3.73 lsd ( which is going to suck on this trip ), although i will need to put on a new oil pan gasket before i go, it has started leaking oil... but thats honestly all i can think of
            • Collin
              • 1736
              T-belt, water pump? My vert does 400 miles every few months when I visit my family, no problems besides road noise.
              The Keystone Killers
              With 73k+ post, you'd think he'd have learned a little about life.
              • brantleyr
                • Apr 2008
                • 375
                nope...
                • Collin
                  • 1736
                  nope...
                  Do you have records of either being done prior to your owning the car (preferably within the last 60-80K miles)?
                  • brantleyr
                    • Apr 2008
                    • 375
                    not to my records
                    • Collin
                      • 1736
                      not to my records
                      Do it, do it now. Better yet do it yesterday. If that timing belt goes while you're driving your valves are going to get their asses whooped by your pistons. It's one of the downsides of an interference motor, where the pistons and valves occupy the same space but never at the same time.
                      While you're in there do the water pump, it's the easiest time to get it done.
                      • Tangent
                        • Mar 2004
                        • 476
                        One thing I always do before long trips is put together a kit with the most common tools I might need. The only thing worse than having a part fail on you 600 miles from home is needing to spend 10X as much as you normally would because someone else has to do the work.
                        • Collin
                          • 1736
                          I happen to have all the necessary parts in my closet if you're interested, if not still get that shit done.
                          • brantleyr
                            • Apr 2008
                            • 375
                            how much downtime are we talking to get this done, this is my daily driver...
                            • ECVCHAMP
                              • Jan 2009
                              • 37
                              I had to learn that one the hard way (New engine:blowup:)
