Question?
    Question?
    so I just bought an 86 325E its my first e30...its an old car so of coarse it needs work im doing the Tbelt and all the front seals also the fuel hoses and top coolant hoses..and the oil pan gasket...i have a pretty bad oil leak! but before 30 mph its pretty smooth but from like 30-40 it vibrates quite a bit!! and im not sure what it is...oh and im rebuilding the caliper on the front pass. side cuz its starting to bind up. could that be a part of the issue? it has a newer driveline could they have possibly screwed it up and put it on 180 degrees off? idk why it happens but thought some of you have experienced this and know!
    WTB: 4door cardinal red interior
    Having a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gay.
    Check tire balance first. Make sure everything is tight. Start small and cheap when diagnosing.
      what wheels are you running? stock/aftermarket ? are they hub centric & not lug centric?
      how bad is that caliper dragging/binding? that can be the culprit too.
