I was at the Pick-n-Pull Import yard near my house (in Rancho Cordova, CA) this morning and and found that they had 2 facelift E30's, a rarety indeed. I picked up an extra ellipsoid assembly (for spare parts), a set of pitted but uncracked fog lamps, and a unique leather one-piece e-brake handle and boot. In case anyone is interested, there is an M-Tech I steering wheel and a black vinyl "lux" rear seat (arm rest and head rests!!) among other usable parts still available.
UPDATE:
So, assembled all of the pieces I needed and got to work on the install. As you can see from the first pic, the fog lights cleaned up pretty well. I tried polishing them to no avail, so I used the clear coat from my wheel paint and that helped quite a bit. Once I covered them with Lamin-X, its difficult to tell they were ever pitted. The job is still not finished though. I still have to get the wiring for the switch correctly mounted. I also have to install the indicator light in the dash. I was able to get everything else connected though. I can hear the relay click as I press the fog light switch, but the lamps don't come on. I have to see if voltage is getting to the lamps. If so then I have bad bulbs. We'll see. In the mean time here are progress pics. Enjoy!
UPDATE:
