Template for pin-mounted hood
    Anyone has something like that?
    I found a reasonable priced light hood intended for pin mounting.
    Any DIY on that?
    figure out where you are going to mount your hood pins, mount them, then take some masking tape and put it on the under side of the hood approx where you think the pins will hit. close the hood and bounce it off of the pins a few times. now drill the holes where the pins left the marks in the tape.
    start with a smaller drill bit then you need incase you need to adjust the hole.
    DONE
      Thanks! One more thing - how about using stock slider-roller things to hold the windshield side of the hood? Yay or nay?
